Topic "dll registration error"
mrsmalltalk
hi,
i'm trying to integrate winscp dll into dolphin smalltalk dev environment. when i try to register winscpnet.dll i get "winscpnet.dll was loaded but DllRegisterServer entry point could not be found.". any idea what is going on? i'm using winscp 5.8.1 beta on win 7.
thanks
How are you trying to register the DLL?
Did you read this?
https://winscp.net/eng/docs/library_install#registering
mrsmalltalk
Did you read this?
yes. i successfully registered it using dos command window and generated a tlib.
in order to use it within dolphin you need to have its tools register the dll and tlib. when i do either of these i get errors.
john
No you do not:
http://stackoverflow.com/q/38376260/850848
