Topic "Is WinSCP.Session.GetFiles synchronous or asynchronous?"
mlunny
We are using a current version of the PowerShell version of WinSCP. I have not been able to determine from the documentation if the WinSCP.Session.GetFiles method is synchronous or asynchronous.
We are transferring files in a batch. After the batch has transferred files, the files are to be moved to a remote directory. Occasionally, the MoveFile method fails for individual files in the batch. We have checked and the permissions on the file are all the same.
sample.txt (1.45 KB) [Download]
Description: code snippet
Synchronous. That's the default. I do not think there's any point mentioning that a method is synchronous. Majority is.
If you have problems, attach a session log file.
Btw, did you check that you are not trying to move the file over an existing file?
