Unable to find files
josephvg
NJ
I am searching for the following file "1234.test.txt" in a SFTP directory.
I tried using *.*.txt, *.test.txt etc but it doesnt work with GetFiles method.
It works only when I give complete file name.
Kindly advise
Re: Unable to find files
Please attach a full session log file showing the problem with the *.test.txt (using the latest version of WinSCP).
