Topic "Script automatic sync FTP always compare all the files"
Young
Each time i run synchronize script, it always compare all folders from my local dir to FTP dir, any ways to only compare files from 4days ago? The size is TB so it takes a very long time to sync.
option batch continue
open ftpserver
synchronize -filemask=">4D" local "mydir" "ftpdir"
it's not working, it still compares all of my files to ftp server
Young
Update:
I have to use this now:
option confirm on
open ftpserver
get -neweronly "ftpdir/*>2D" "mydir\*"
Should i change confirm on to off or not ? I want to skip to replacing existed files
open ftpserver
Even if you specify a filter for the files, WinSCP still have to list all files to find what files are those matching the filter.
Young wrote:
Update:
option confirm on
open ftpserver
The get command cannot skip existing files. The synchronize is the command to use. If the get would be skipping existing files, it would have to do exactly the same what the synchronize does.
