Topic "Errror trying to upload file using vb.net Code"
Swindellvc@cofc.edu
I'm trying to upload a file and I'm getting
Error:Cannot overwrite remote file '/studentlists'.$$ <which is the directory on the upload and is empty when testing code
Press 'Delete' to delete the file and create a new one instead of overiting it. $$
I'm using the VBA code...
is there a way to overwite an existing file?
or sync a single file using VB?
blah blah blah for SessionOptions
mySession.Open(mySessionOptions)
' Upload files
Dim myTransferOptions As New TransferOptions
myTransferOptions.TransferMode = TransferMode.Binary
transferResult = mySession.PutFiles("\\aiken\ProdCognos\ITExtracts\studentlist.csv", "\studentlists", False, myTransferOptions)
' Throw on any error
transferResult.Check()
' Display results
Dim transfer As TransferEventArgs
For Each transfer In transferResult.Transfers
MsgBox("Upload of " & transfer.FileName & " succeeded")
Next
The correct syntax is:
transferResult = mySession.PutFiles("\\aiken\ProdCognos\ITExtracts\studentlist.csv", "/studentlists/", False, myTransferOptions)
As documented:
https://winscp.net/eng/docs/library_session_putfiles
