Topic "Parametrized script help"
victority
I am trying to make a parametrized scrip to upload jpg files, but I got stuck.
I have servers.bat :
@echo off
"C:\Program Files (x86)\WinSCP\winscp.com" /script=D:\Script\script.txt /parameter ftp://user:pass@server1.com/
"C:\Program Files (x86)\WinSCP\winscp.com" /script=D:\Script\script.txt /parameter ftp://user:pass@server2.com/
"C:\Program Files (x86)\WinSCP\winscp.com" /script=D:\Script\script.txt /parameter ftp://user:pass@server3.com/
"C:\Program Files (x86)\WinSCP\winscp.com" /script=D:\Script\script.txt /parameter ftp://user:pass@server4.com/
"C:\Program Files (x86)\WinSCP\winscp.com" /script=D:\Script\script.txt /parameter ftp://user:pass@server5.com/
And I have script.txt :
open %1%
put \\Files\Upload\*.jpg /
Since the server5.com should have a different path to remote location (put \\Files\Upload\*.jpg /Folder), here the problem starts.
I tried to do with additional parameters, but I could not do anything.
Please help.
Thank you in advance.
Victor
In this particular case, you can make the path part of the URL:
"C:\Program Files (x86)\WinSCP\winscp.com" /script=D:\Script\script.txt /parameter ftp://user:pass@server5.com/some/path/
Note the /some/path/.
The script:
open %1%
(i.e. no second argument of the put)
The script:
open %1%
Hello Martin,
Thanks for your reply.
I tried as you wrote. However, regardless of the path that I have added on the end, upload files to the root.
("C:\Program Files (x86)\WinSCP\winscp.com" /script=D:\Script\script.txt /parameter ftp://user:pass@server5.com/some/path/)
Do you have any other idea?
The script:
open %1%
I found where the problem is, I forgot to take off "/" from the script
Now works perfectly, thank you.
Best regards.
