Topic "Check for Updates fails with error 80092013"
shaun.merrill@...
Version 5.9 (Build 6786)
Choose Help > Check for Updates from the menu.
Error:
Certificate not trusted.
Error: 80092013, Chain index: 0, Element index: 0
Server certificate verification failed: issuer is not trusted
Thanks. We will take a look.
testing
Error:
I have the same issue
Arnaud
Error:
feR
Recently install same versión on two differents Windows 7 computers, on 64 bits doesn't works but on 32 bits works fine.
Are you all getting the exactly same error message? Including the Error: 80092013?
Do you have some 3rd party firewall or other security solution?
EJHonda
Hi Martin,
I have the same issue. I looked at your profile, but it shows a blank for your email address.
Error: 80092012, Chain index: 0, Element index: 0
EJHonda
Created an account, got your email, sending you some details shortly.
EJHonda
We disabled SSL inspection for the WinSCP.net site on our firewall, and the check update function completes successfully.
