Topic "dont warking same script on winscp.com 5.9"
Mikage
Only winscp.com 5.9 on Windows7(32bit), no longer work is Script that was moving before
CommandLine as follows:
Quote:
set lf=%date:~-10,4%%date:~-5,2%%date:~-2,2%
"C:\winscppath\winscp" /script="D:\dairywork\trans_serv1.scr" /log="M:\ServerLogs\serv1\scplog\log_%lf%.log" > M:\ServerLogs\serv1\scplog\bat_%lf%.log
file bat_yyyymmdd.log Appears as follows:
Quote:
No mapping for the Unicode character exists in the target multi-byte code page
file log_yyyymmdd.log does not exist
but. Same Script(trans_serv1.scr) is operating properly under the following Client conditions:
winscp.com 5.9 on Windows StorageServer 2012R2(64bit)
winscp.com 5.7.7 on Windows StorageServer 2012R2(64bit)
winscp.com 5.7.7 on Windows 7(32bit)
trans_serv1.scr Script as follows:
Quote:
open user1@serv1
option batch on
option transfer binary
option reconnecttime 30
synchronize local "M:\ServerLogs\serv1\http\purelog" /inetpub/logs/LogFiles/Apache
synchronize local "M:ServerLogs\serv1\ftp\purelog" /inetpub/logs/LogFiles/FTPSVC2
close
serv1 Setting at All Client as follows:
Quote:
Password is saved
UTF-8 Encode is Auto
Targer serv1 Server works IIS-FTP on Windows 2008R2
Target FTP Site Settings : Allow UTF-8 is True
(but , it did not change even if set to False)
If Using winscp.exe 5.9 GUI will work without problems.
I do not only continue to use winscp.com 5.7.7 ?
But is another matter , I want to quit to output the raw password to log.
Is your script file in UTF-8 encoding?
https://winscp.net/eng/docs/scripting#using_scripting
Mikage
Thanks for advice.
Problem has been able to resolve.
