Topic "Synchronize stops with one file error"
TonyZee
Hi:
I'm trying to use the synchronize command to backup files.
However, if for whatever reason, a file can't be opened locally, the script exits with a '1' and the backup stops.
Is there a way to tell WinSCP to keep going after an error?
Thanks!
TonyZee
For those of you with this problme, I discovered the answer:
It's a simple as using 'option batch continue' in the script.
This will skip files that can't be opened.
Enjoy!
However, I seem to have a problme spelling the word problme.
