Topic "Copied file gets incorrect name"
waytenhwaet
Using SCP I copied a file named
deleteme.
from a remote Linux server to my local machine but the copied file got named
deleteme%2E
Then I copied a file
qwerty%2e
to the remote where it got named
qwerty.
I expected the filenames not to change.
WinSCP 5.9 (Build 6786) on Windows 8.1 was used.
The reason behind this is that it's not trivial in Windows to create a file ending with dot. Historically it was not allowed. It's possible now, but it's complicated, so WinSCP preserves the dot this way. The same way it preserves other not-allowed characters in files names (like slashes and colons).
You can disable this in transfer settings. But you will lose the dot:
https://winscp.net/eng/docs/ui_transfer_custom#filename_modification
