Topic "Too many successive open/closes in a script results in failure"
Charles Sorgie
WinSCP Version 5.9 (Build 6786) (OS 6.1.7601 Service Pack 1 - Windows 7 Professional)
Unclear when problem started.
Scripting
I have a script that looks like this:
option batch abort
open <sitename1>
lcd "<directory1>"
get *.* -preservetime -delete
close
open <sitename2>
lcd "<directory2>"
close
open <sitename(n)>
lcd "<directory(n)>"
close
There are variations of the get command but basically the script open, gets, and closes a lot of sessions. Only one session is open at a time.
The problem appears to be that after about 20 open/closes the script fails as follows:
Looking up host "<hostname>" for SSH connection
Connecting to xxx.xxx.xxx.xxx port 22
We claim version: SSH-2.0-WinSCP_release_5.9
Network error: Software caused connection abort
If I comment out the portion of the script that fails, the next portion fails. If I comment out everything before the portion that fails, the failed portion and the remainder of the script completes successfully:
Script: close
Closing connection.
Sending special code: 12
Sent EOF message
The only solution I have at this point is to break the script up into separate tasks.
Is it the same host or different each time?
Same host each time.
Configuration was HKCU which worked because task is running as local admin. Switched to INI as part of debugging process, no change.
All sites can be opened via the graphical interface without issue.
Failed access never makes it to the server logs because SSH handshake fails.
Update: I broke the job up into separate bat files such that Win_SCP is invoked in turn for each site. This still produced the same error at the 16th site. I then added a timeout 10 between the invocations and the task is completing successfully. I haven't tried less than 10 seconds. So it seems the VM running the task is getting bogged down somehow. A simple (and general) fix might be to add a timeout script command. Hope this helps.
...or I suppose Win_SCP could wait and retry the operation? Curious to see what you discover.
I suppose that the SSH server or the machine firewall (or iptables or similar tool) just blocks too many connection attempts from the same client. It's quite common.
Why are you re-connecting the same host? Why don't you reuse the connection?
