Topic "Is distance a problem?"
ChanLB
I've been trying to upload data (3 - 4 gb) from a site in Mexico to a server in Massachusetts and have been unsuccessful. I've been receiving Error connection reset by peer: Abnormal exit messages. Do you have any ideas as to what the cause may be? Thanks. Twisted Evil
If the connection is dropped by the other side, you should better check the other side first Smile Even if the problem is on WinSCP side, they should at least know why they close the connection.
