Topic "SSIS 2012 TransferOptions.FileMask causing exception has been thrown by the target of an invocation"
loriechevalier
Everything works great until I add the filemask...Once I do, I get an exception has been thrown by the target of an invocation...Could you please tell me what I'm doing wrong?
TransferOptions lTransferOptions = new TransferOptions();
lTransferOptions.FileMask = "LOR*.zip" ;
TransferOperationResult lTransferResult = lSession.GetFiles(remotePath, localPath, false, lTransferOptions);
lTransferResult.Check();
Thank you
The exception must have an inner exception with more details.
Or attach a session log file.
loriechevalier
Thank you for the reply. Actually this filemask now works (some weirdness going on there). I now need to add an exclusion filemask
Would this be the correct way to exclude any files with the name of RSCH-*.zip?
lTransferOptions = | "RSCH-*.zip";
Thanks much,
Lorie
This is the correct way:
lTransferOptions = "| RSCH-*.zip";
