Topic "get -latest /home/t603/*.txt is not found, get -latest /home/t603/my* is found"
t603
I have a question regarding file mask used in "get -latest" scripting command.
When I define my script as
it does not work, while
it does work.
Can I ask You, if file mask like /home/t603/my*.txt is supported? In GUI Find: File mask it is supported.
Thank You in advance for Your answer, Stepan
t603
I am using the latest 5.9 (Build 6786)
t603
Hello, back from my holidays... I am sorry, WinSCP works OK, it was a problem between my chair and keyboard. Diky, Stepan
