Custom command - zip and download
peterhammer
Uruguay
Hi, i would like to make a custom command to zip and download a file in one step.
The zip part is already done, but i dont know if i can append the download instruction...
Any suggestion?
Best regards,
Federico.
Re: Custom command - zip and download
You would have to write a script that opens its own session (to the same host), creates the ZIP and downloads it. The script can also refresh WinSCP GUI file panel when it finishes.
See https://winscp.net/eng/docs/guide_custom_commands_automation
You basically need script like this:
https://winscp.net/eng/docs/library_example_zip_and_upload
Except you have to create the ZIP remotely (using the Session.ExecuteCommand) and download it (using the Session.GetFiles)
