Topic "ini file location"
Per Ason
Hi, and thanks for the best file transfer app I have used (+20 years in development).
When it comes to the ini file location, where WinSCP looks in the application data directory of the user profile, i.e. C:\Users\%username%\AppData\Roaming\WinSCP.ini
May I ask if this could be altered (or extended) to cover also a folder named WinSCP, i.e. C:\Users\%username%\AppData\Roaming\WinSCP\WinSCP.ini
I would also appreciate if the default location of the winscp.rnd file were in the very same folder.
Am asking as I would like to not have stray files in the C:\Users\%username%\AppData\Roaming root folder.
BR, Per
For INI file, see:
https://winscp.net/eng/docs/config#ini
In general, the INI file is intended for a portable use, where the INI file is stored along the .exe file. There's really no point using the INI file with an installed version.
You can however specify any path you want with the /ini[/n] command-line switch.
https://winscp.net/eng/docs/commandline#configuration
There's current no way to change the location of the [m].rnd
file.
