Topic "Permissions as set by cygwin's chmod not being copied"
laggingreflex
I'm using `WinSCP.com /command keepuptodate` to keep a folder in sync with a server. I have several `.sh` script files which should have `+x` permissions and I've set them as such using cygwin's `chmod` and they indeed show `+x` when using cygwin's `ls`, but when the file is transferred by WinSCP it doesn't have the same permissions on the server. Also changing the permissions doesn't trigger `keepuptodate`.
Is it possible to sync permissions?
laggingreflex
Just to clarify, I'm setting `+x` permission on a new file on my Windows machine and expecting that the `+x` permission will be copied to the remote server. But the file on the server only has +r permissions and I have to manually `chmod +x` on the server. After that it's fine, it doesn't unset the remote file's `+x` after further changes to the file are synced. I'm guessing the current default behavior is not to alter permissions at all on the server, or to leave the permissions as they were on the server for a file if it already existed, right?
So is it possible to actually keep the file permissions in sync also?
I also wouldn't want to use `-permissions=0777` on all files, I just want it to copy the files' original permissions as set by cygwin on windows (client) to the server.
laggingreflex
Ahh never mind, further searching tells me it might not actually be possible http://stackoverflow.com/questions/15761461/setting-file-permissions-when-uploading-with-ftp-protocol-in-winscp. [/url]
The primary problem that WinSCP as a native Windows application is not aware of Cygwin permissions.
