Topic "Proxy settings"
BorisKnez
Hi. Im trying to use your .NET c# library for uploading files to ftp through proxy. I dont know how should I set the proxy settings. The filezilla settings works as on the screen here: http://shrani.si/f/2q/87/4cUSAIoN/proxy.png
Could you please help me.
The easiest solution is to configure the session in WinSCP GUI and have WinSCP generate the code for you.
See
https://winscp.net/eng/docs/ui_generateurl
https://winscp.net/eng/docs/guide_filezilla_automation
https://winscp.net/eng/docs/rawsettings
BorisKnez
See
Thanks for that. I have managed to get this working.
Now i have another problem. I have used it on a production server now I get an error: Transfer channel can't be opened. Reason: No connection could be made because the target machine actively refused it.
If I use WinSCP directly on that same server to upload a file it works as expected, but when I run the same putfile thround the code I get the above error. Do you know what could be wrong? Thanks a lot
It's probably a firewall that blocks the transfer connection.
