Topic "Two things: exit command and ovewriting of the log file"
leonardo07746
good morning, I need some help on these, the first problem is that the Exit command isn't closing the prompt when the script has finished the job, the cause is that it doesn't run again at the scheduled next time, the prompt stood there just open, the script goes like this
Quote:
# Automatically abort script on errors
option batch abort
# option transfer binary
cd c:\Program Files
cd WinSCP
@echo off
winSCP.com /command ^
"option batch abort" ^
"open ftp://ftpmetropolitano:ftpmetro@192.168.xxx.x1/ " ^
"synchronize local -delete -filemask=|*.rar C:\Sabic\JOURNAL /Journals/TRASVAL/ " ^
"/log=C:\logsdelScript2.log" /loglevel=1" ^
"exit"
and the second is that the log file has just increased almost a 1 gb file size, how can I do to create a diferent log file every time the script activates and not overwrite the same log every time.
THANKS
leo
You have to move the exit after the other commands (before the /log). And use some log file name patterns to make the name unique.
   "exit" ^
   "/log=C:\logsdelScript2_!Y!M!D!T.log" /loglevel=1
leonardo07746
YEP, the not overwriting request and patterns work like a charm, thanks, but the exit command is not working properly, the prompt is there everytime.
Does the "exit" command need to be before the "/log.............? that isn't working for me, what am i missing
"exit" ^
"/log=C:\LOGS_JOURNALS\logsdelScript_!Y_!M_!D_!T.log" /loglevel=1"
leo
This is correct. Make sure there's no space after all ^'s and there's at least one space on the following lines.
If you have problems, post a complete batch file as an attachment.
