Topic "Honestly its Good to use but it Disconnect frequenctly"
jalpesh
Wink Wink Wink
I like WinSCP to use but Big Big headache when it Disconnect and
Really it Disconnect like seconds in watch
Help whats reason or solution for this
Are you getting the same problem with other clients?
