Topic "Logging deleted files in SynchronizeDirectories method"
DanD
Hi
I'm new with WinSCP and I try to convert all my synchronize app with WinSCP. I'm using PowerShell. I tried the example script with add_FileTransfered method that work fine but now I searched a way to catch deleted file for logging it. Does it have an event catcher or something else to og the deleed files?
Thank you!
Dan
This is not supported.
But you can enumerate files before and after the synchronization and find the differences.
See
https://winscp.net/eng/docs/library_example_watch_for_changes
http://stackoverflow.com/a/37695309/850848
