Topic "List remote directory on the left pane."
glcp
Like title says, I want to list a remote directory on the left pane, so that I can compare its contents with another remote directory on the right pane.
My WinScp version is 5.5.1 Build 3970
Any help will be much appreciated.
See https://winscp.net/eng/docs/faq_filemanager
glcp
Thank You for your suggestion.
The solution that I have adopted yesterday was to switch to the Explorer interface, start a second WinScp instance and compare the two explorer instances side by side.
