Topic "Can I Move Files on FTP Host Server?"
SalientAnimal
Hi All,
I've started setting up the automation of picking up files off of the FTP Host, and all of this is working as intended thus far.
The next step I need to achieve, and I'm not sure if its possible or not is to move the source file on the FTP Host to another directory on that FTP host once it has been copied without changing the name of the file on the host server.
The script I am currently using, does not seem to work. Some guidance please?
@echo off
winscp.com /script=dailyimport.txt
if %ERRORLEVEL% neq 0 goto error
echo Download succeeded, moving local files
move *.csv /downloads/MySQL/downloaded
exit /b 0
:error
echo Upload failed, keeping local files
exit /b 1
My dailyimport.txt looks like this:
# Connect
open ftp:details
# Change remote directory
cd /downloads/MySQL
# Force binary mode transfer
option transfer binary
# Download file to the local directory
get filename001_*.csv "E:\Data\DailyImports\newfilename001.csv"
get filename002_*.csv "E:\Data\DailyImports\newfilename002.csv"
get filename003_*.csv "E:\Data\DailyImports\newfilename003.csv"
mv *.csv cd /downloads/MySQL/downloads/*.csv
# Disconnect
close
# Exit WinSCP
Use mv *.csv /downloads/MySQL/downloaded/* in the WinSCP script file (dailyimport.txt).
