Topic "Put this in the wrong forum I think - Recursive calls not allowed"
KLH
I have established that directories exist. I go through the rfi.names list to removed them but always get the Recursive calls not allowed.
public RemovalOperationResult RemoveFiles(string path)
          session.Open(Config.FtpSessionOptions);
          return session.RemoveFiles(session.EscapeFileMask(path));
 RemoteDirectoryInfo rdi = ftpsSession.ListDirectory(ftpPath);
 foreach (RemoteFileInfo rfi in rdi.Files)
    if (rfi.IsDirectory)
         RemovalOperationResult ror;
         ror = ftpsSession.RemoveFiles(ftpPath + rfi.Name);
         if (ror.IsSuccess)
         foreach (RemovalEventArgs removal in ror.Removals){
            log.Event("Removal of " + removal.FileName + " succeeded");
     else
         log.Event("Removal failed.");
         return false;
It doesn't seem to matter what the path is.
It does seem to be resolving to the right point. Everything else I am doing besides removal is working happily. I am very confused.
KLH
I resolved part of the problem but I am still getting the same Recursive calls problem when I try to use the following:
Pretty much every call I attempt to make to session.RemoveFiles is resulting in a Recursive Calls are not allowed response in the Results.
I have tried "xxxx.txt", "\xxx\xxx.txt", "*" "\" no paths seem to work. I checked the permissions on the account I use to create the session and they are fine. I can manipulate everything properly with an FTP client. Just not with the WINSCPnet API. Anyone have any ideas?
https://winscp.net/forum/viewtopic.php?t=23564
