Probleme with file's autorization
Johns57
I have a probleme, for exemple, I upload and open a "CSV" file (owner : root, group : psacln, size of file : 468 KB) usind winscp (sftp with an account root) and notepad++.
I make any modification in my file.
And I save the file to my server.
When I verify the file's autorization of my "CSV", the owner is "root", ok, but the group is "root", it is'nt normal...
Thank you for your help.
Johnny
Johns57
More information
Just one more information :
The bug above is present when the option "Options" / "preference" / "endurance" / "Enable transfer resume/Transfer to temporary filename for" : choice "File above : 10KB" is selected.
If the option : "Options" / "preference" / "endurance" / "Enable transfer resume/Transfer to temporary filename for" : choice "All files" is selected, the bug is ALWAYS present, for all files.
If the option : "Options" / "preference" / "endurance" / "Enable transfer resume/Transfer to temporary filename for" : choice "Disable" is selected, the bug is NEVER present.
And my version of winscp : 5.9.1 (Build 6885)
