Topic "Timestamp of remote files / directories is different between 5.1.0 and 5.9.1"
franksoltis
Hi ..
while testing migration from 5.1.0 to 5.9.1 we experienced a timestamp problem.
5.9.1 file/dir listing of change date shows 1 hour less than 5.1.0 version.
If we would move to new version, our synchronize would recognize all files as changed ... not good
- we use SFTP and synchronize function.
- Environment config for both installations:
- Daylight saving time : Adjust remote timestamp to local conventions
- tests from same client to same server with same user.
Any ideas what could be the problem ?
Regards Juergen
Please post a full session log file from both versions.
Hi Martin ... I uploaded the logs for both versions.
Thanks in advance ...
V5-9-1.log (156.11 KB) Private file
Description: In directory listing I have
+ 1 hour for the timestamp
V5-1-0.log (170.96 KB) Private file
+ 2 hours for the timestamp
Thanks for the logs. Though I do not see any difference. Can you name one specific file that you have the problem with?
How exactly do you check for the difference? Maybe some screenshot may help explaining the problem.
franksoltis
lcd %TARGET_DIR%
cd %SOURCE_DIR%
dir
bin
synchronize local -delete -mirror %TARGET_DIR% %SOURCE_DIR%
dir
bye
Screenshots added ...
You see 1 hour difference ...
If I start synchronize now, my job would detect every file as "new" and synchronize everything -
In my case, that would be some 60 GB of data and ... I have problems with post processing, because these data have already been processed.
Description: 5.1.0 left ... 5.9.14 right
So please attach a session log file for that (from both versions).
Use the /log=... command-line switch.
franksoltis
Actually I couldnt do the synchronize .. but in the /log you see the result of the dir command ... that should be the basis for the synch ... isnt it ?
Hope its enough information for you.
Martin510.log (59.9 KB) Private file
Description: (none)
Martin591.log (61.68 KB) Private file
Description: (none)
Thanks.
It's most probably due to this change:
https://winscp.net/tracker/show_bug.cgi?id=1060
If you want adjust the timestamps of local files to avoid to re-download them all, run one-time timestamp synchronization.
See the Synchronize timestamps mode:
https://winscp.net/eng/docs/ui_synchronize
franksoltis
Thanks a lot .. we will update to 5.9.1 and as first step : synchronize timestamps
Regards
Juergen
