Topic "Splitting WinSCP.ini"
Eistee
first big thanks for winscp! We moved here after using filezilla for years without caring about plain text password storage Twisted Evil
I use winscp portable and but it with the WinSCP.ini under git control to sync my saved connections between two maschines. But because auf the ini vars Jumplist, LastStoredSession and RunsSinceLastTip the WinSCP.ini is modified all the time even if i just open winscp.
Now my request: Can you please consider splitting WinSCP.ini into two files? For example WinSCP.ini for all the real config options and connections and Workspace.ini for all the permanently changing / temporary vars like Jumplist, LastStoredSession and RunsSinceLastTip?
Thanks in advance!
Thanks for your suggestion. Will consider it.
Eistee
Great! Thanks!
I hope to see this feature soon Very Happy I can do beta testing if you like...
