Topic "Searching for a text string among files on remote"
Anon0007
Hi, Is there any way that I can ask WinSCP to search all the files on a remote station (in the current displayed directory, with or without any filename filter in operation) for a specified text string, and to display both the filename and the complete line of text that is matched. I am not familiar with Linux commands, but the MSDOS equivalent would be
FIND "text string" path:filename*.*
Many thanks
You can use this extension:
https://winscp.net/eng/docs/library_example_recursive_search_text
The latest versions of WinSCP come with the extension pre-installed.
