Topic "Timestamp get current date and hour"
Rirbeiro
Hi Guys,
I have created a script to get the files from remote to local directory by current date, as below:
"get -filemask=*>=%TIMESTAMP#yyyy-mm-dd% /vv447Q/pdfdanfe/* C:\pdfxml_totvs\%TIMESTAMP#yyyymmdd%\"
Is it possible get the file by current date and hour?
Best Regards,
Ricardo Ribeiro
What does it mean "get the file by current date and hour"?
Hi Martin,
The setting on filemask on my script is (-filemask=*>=%TIMESTAMP#yyyy-mm-dd%). This script is working, download the files that has been created on current date.
I would like to download the files by current date and last hour. Is it possible?
Thank you
Rirbeiro
Hi Martin,
Is it possible to use the "sinchronize" with "-filemask", just to sinchronize the data files on the current date?
Best Regards,
Sure. The same way:
-filemask="*>=%TIMESTAMP#yyyy-mm-dd hh:00:00%"
Though you may want to use a relative time:
-filemask="*>=1H"
See
https://winscp.net/eng/docs/file_mask#size_time
https://winscp.net/eng/docs/scripting#timestamp
Yes, again, the same way.
Rirbeiro
Thank you Martin.
It has worked very well.
:lol:
