Topic "Check file size before uploading"
alexsambi25
The script working fine, but from now I need to check the file size before start uploading.
here is my codes.
@echo off
"C:\Program Files (x86)\WinSCP\winscp.com" ^
  /command ^
    "open sftp:// etc....^
    "put C:\fileput.xml /home/import/" ^
    "exit"
How I can make this codes to check the size C:\fileput.xml if the file size less than 100 MB so stop uploading.[/code]
See http://stackoverflow.com/questions/1199645/how-can-i-check-the-size-of-a-file-in-a-windows-batch-script
Though you can also abuse size-constraint in WinSCP file mask:
"put C:\fileput.xml -filemask=*>100K /home/import/" ^
See https://winscp.net/eng/docs/file_mask#size_time
