Topic "Need very urgent help on a WinSCP issue related to file getting transferred wrong location."
9sairohit@...
Hello guys,
I am using WinSCP Version 5.7.6. Files are uploaded to '/home/user1/' instead of '/TA/MS/I3', though WinSCP shows in the logs that files got uploaded successfully. Please find the detailed logs in the attached log file. It's very urgent and important and if some one can give any clue as what is happening and why it is happening it will be of great help.
< 2016-08-23 23:45:35.029 350 Restart position accepted (0).
. 2016-08-23 23:45:35.029 Sending dummy command to keep session alive.
> 2016-08-23 23:45:35.029 TYPE A
< 2016-08-23 23:45:35.029 200 Switching to ASCII mode.
> 2016-08-23 23:45:35.029 TYPE I
< 2016-08-23 23:45:35.029 200 Switching to Binary mode.
> 2016-08-23 23:45:35.029 PWD
< 2016-08-23 23:45:35.029 257 "/TA/MS/I3"
. 2016-08-23 23:45:35.029 Starting upload of E:\User\RD1\M_Imp.tiff
> 2016-08-23 23:45:35.029 PASV
< 2016-08-23 23:45:35.029 227 Entering Passive Mode (10,10,2,157,111,61)
> 2016-08-23 23:45:35.029 STOR M_Imp.tiff
. 2016-08-23 23:45:56.047 Transfer channel can't be opened. Reason: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
. 2016-08-23 23:45:56.047 Copying files to remote side failed.
* 2016-08-23 23:45:56.047 (ExtException) **Transfer channel can't be opened. Reason: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.**
* 2016-08-23 23:45:56.047 Copying files to remote side failed.
. 2016-08-23 23:45:56.047 Asking user:
. 2016-08-23 23:45:56.047 Error transferring file 'E:\User\RD1\M_Imp.tiff'. ("Transfer channel can't be opened. Reason: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.","Copying files to remote side failed.")
< 2016-08-23 23:45:56.047 Script: Error transferring file 'E:\User\RD1\M_Imp.tiff'.
< 2016-08-23 23:45:56.047 Script: Transfer channel can't be opened. Reason: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
< 2016-08-23 23:45:56.047 Copying files to remote side failed.
* 2016-08-23 23:45:56.047 (EScpSkipFile) Error transferring file 'E:\User\RD1\M_Imp.tiff'.
* 2016-08-23 23:45:56.047 Transfer channel can't be opened. Reason: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
. 2016-08-23 23:45:56.047 Script: Failed
. 2016-08-23 23:45:56.047 Dummy directory read to keep session alive.
. 2016-08-23 23:45:56.047 Retrieving directory listing...
> 2016-08-23 23:45:56.047 CWD /home/user1/
< 2016-08-23 23:46:35.021 425 Failed to establish connection.
. 2016-08-23 23:46:35.021 Could not retrieve directory listing
> 2016-08-23 23:46:35.099 Script: put -delete -nopermissions -preservetime -transfer="automatic" -filemask="|*.jpg" -- "E:\User\RD1\*" "/TA/MS/I3"
. 2016-08-23 23:46:35.099 Copying 14 files/directories to remote directory "/TA/MS/I3"
. 2016-08-23 23:46:35.099 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 0100; Resume: S (102400); CalcS: No; Mask:
. 2016-08-23 23:46:35.099 TM: M; ClAr: No; RemEOF: No; RemBOM: No; CPS: 0; NewerOnly: No; InclM: |*.jpg; ResumeL: 0
. 2016-08-23 23:46:35.099 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2016-08-23 23:46:35.099 File: 'E:\User\RD1\M_Imp.tiff' [2016-08-23T15:31:32.728Z] [57631108]
. 2016-08-23 23:46:35.099 Copying "E:\User\RD1\M_Imp.tiff" to remote directory started.
. 2016-08-23 23:46:35.099 Binary transfer mode selected.
< 2016-08-23 23:46:35.099 250 Directory successfully changed.
. 2016-08-23 23:46:35.099 Starting upload of E:\User\RD1\M_Imp.tiff
> 2016-08-23 23:46:35.099 TYPE A
< 2016-08-23 23:46:35.099 200 Switching to ASCII mode.
> 2016-08-23 23:46:35.099 PASV
< 2016-08-23 23:46:35.099 227 Entering Passive Mode (10,10,2,157,136,83)
> 2016-08-23 23:46:35.099 LIST
< 2016-08-23 23:46:35.099 150 Here comes the directory listing.
. 2016-08-23 23:46:35.099 <Empty directory listing>
< 2016-08-23 23:46:35.099 226 Directory send OK.
> 2016-08-23 23:46:35.099 TYPE I
< 2016-08-23 23:46:35.099 200 Switching to Binary mode.
< 2016-08-23 23:46:35.115 227 Entering Passive Mode (10,10,2,157,166,132)
> 2016-08-23 23:46:35.115 STOR M_Imp.tiff
< 2016-08-23 23:46:35.115 150 Ok to send data.
< 2016-08-23 23:46:35.739 226 File receive OK.
> 2016-08-23 23:46:35.739 MDTM 20160823153132 M_Imp.tiff
< 2016-08-23 23:46:35.739 213 File modification time set.
. 2016-08-23 23:46:35.739 Upload successful
. 2016-08-23 23:46:35.739 Transfer done: 'E:\User\RD1\M_Imp.tiff' [57631108]
. 2016-08-23 23:46:35.755 File: 'E:\User\RD1\M_Imp_1.tiff' [2016-08-23T15:33:45.757Z] [66099680]
. 2016-08-23 23:46:35.755 Copying "E:\User\RD1\M_Imp_1.tiff" to remote directory started.
. 2016-08-23 23:46:35.755 Binary transfer mode selected.
. 2016-08-23 23:46:35.755 Starting upload of E:\User\RD1\M_Imp_1.tiff
> 2016-08-23 23:46:35.755 TYPE I
< 2016-08-23 23:46:35.755 200 Switching to Binary mode.
> 2016-08-23 23:46:35.755 PASV
< 2016-08-23 23:46:35.755 227 Entering Passive Mode (10,10,2,157,54,249)
> 2016-08-23 23:46:35.755 STOR M_Imp_1.tiff
< 2016-08-23 23:46:35.755 150 Ok to send data.
< 2016-08-23 23:46:36.472 226 File receive OK.
> 2016-08-23 23:46:36.472 MDTM 20160823153345 M_Imp_1.tiff
< 2016-08-23 23:46:36.472 213 File modification time set.
. 2016-08-23 23:46:36.472 Upload successful
Thanks. Merci. Gracias. Grazie.
WinSCP FTP Uploads to wrong path.txt (5.91 KB) [Download]
Description: (none)
9sairohit@...
Thanks for the reply Martin.
I need dot net assembly too for the same version in the debug version. I have sent you the mail for the same.
Thanks.
