Topic "WinSCP on Surface Pro 4/Windows 10"
dvmrp
Hi, I read the release note that HIDPI is supported since 5.8.x beta. However the font is still tiny in my Surface Pro, using the latest 5.9.1. Is there any setting required? Thanks.
Please post a screenshot (including some other application for comparison).
dvmrp
Here is the screenshot. The system scaling has already been set to 200%. Thanks for looking into it.
Description: (none)
Did you restart your machine after changing the scaling (as recommended by the "red" label on the screenshot)?
dvmrp
Thanks. The problem is now clear. Whenever I disconnect the surface pro from the external monitor, that message appears because the scaling factor is different for external monitor and built-in display. As a result, the scaling of winscp is not correct until I logout and login again.
Is there any workaround?
Thanks for the feedback. I do not think there's a workaround. We will look into it.
