Topic "winscp does not answer - log: Looking for network events (indefinitely) - winscp.exe is not killed"
PascalF
Hello
my program launches winscp.com as an external process, but it does not answer
then, my program kills winscp.com but winscp.exe is not killed
I wish that
- winscp returns
- (if not) when winscp.com is killed, then winscp.exe is also killed
I used following scripting commands:
- option batch on
- option confirm off
- option reconnecttime=1
I used following switches for the open command:
-rawsettings SendBuf=0 SshSimple=1 (for turning off 'Optimize connection buffer size')
-timeout=7
Must I change commands/switches ?
Thank you in advance!
below are winscp log messages:
**Host is not communicating for 7 seconds.
Wait for another 7 seconds?** ()
Script: Host is not communicating for more than 7 seconds.
Still waiting...
Note: If the problem repeats, try turning off 'Optimize connection buffer size'.
[then, following lines repeat indefinitely:]
Pooling for data in case they finally arrives
Timeout waiting for network events
winscp-log-timeoutDoesNotWork-forum.log (25.9 KB) Private file
Description: (none)
It's not clear to me, if the "does not answer" problem happens always, or sometime only?
The winscp.exe should get killed with the winscp.com. If you run the winscp.com manually from a command-line and kill it with Task Manager, is the winscp.exe killed?
Hi Martin, thanks for your reply, I add precisions
1°) description of anomaly
my program
- launches winscp.com as an external process to several sftp servers.
- if winscp.com does not exit after timeout, then my program kills winscp.com
two configurations (to server-1 and to server-2 )are bad: remote folder does not exist
- program connects to server-1 on non-existing-folder1, then after timeout, my program kills winscp.com, and winscp.exe is killed => OK
- program connects to server-2 on non-existing-folder2, then after timeout, my program kills winscp.com, but winscp.exe is NOT killed => anomaly (I think)
notes:
- program uses System.Diagnostics.Process .NET object and the Kill() method
- program creates winscp.com process with following scripting commands: option batch on, option confirm off, option reconnecttime 1
- program uses following switches for the open command: -timeout=7 -rawsettings SendBuf=0 SshSimple=1 (for turning off 'Optimize connection buffer size')
2°) behaviour of winscp as a command line
2.1°) note: I am prompted
I use option batch on and option confirm off, but I am prompted
winscp> open user@server-2 ...
Active session: [1] ...
winscp> cd /NonExistingDir
Host is not communicating for more than 15 seconds.
Still waiting...
Warning: Aborting this operation will close connection!
(A)bort (53 s):
2.2 °) winscp.com as a command line + kill winscp.com from task manager
- I run winscp.com as a command line
- I open connection to whichever server, I do not change dir
- then I kill winscp.com with Task-Manager (EndProcess, not EndProcessTree)
- it does not kills winscp.exe
I cannot reproduce this.
On Windows 2008 R2 (is this what you are using, right?), I start winscp.com from the cmd.exe console. I do not even connect anywhere nor type any commands, for simplicity. In Task manager I find the winscp.com process and select "End process". Both winscp.com and winscp.exe are killed.
PascalF
Hello Martin, thanks for your reply, I add precision
- I connect to the platform (W2008R2) with User1 identity
- I run winscp.com as a command line with User2 identity
