Topic "Winscp Memory Leaks"
Sheeraz
I am trying to Upload a 11GB file but get regular memory error.
Few things i observed on task manager that Winscp starts consuming high memory i.e. over 1 GB and then it crashes.
Please find attached the command interface .
Winscp.txt (5.42 KB) [Download]
Description: Command prompt file.
sheeraz
Find attached log file. The main problem is that the command desent reload at certain point and have to end task and reload again.
loadAttempt.log (104.06 KB) Private file
Description: (none)
sheeraz16
Email send
sheeraz16
I have reproduce the scenario please check attachment..
Winscp.zip (5.32 KB) Private file
Description: Zip folder
Please read the instructions linked in the email. I need the trace file too. Send the log via email.
