Topic "Per connection option to disable logging"
Jababr
Hello.
First of all: Thanks for the best client ever made.
I would like to suggest add an CheckBox on "Advanced Site Settings", where enable or disable logging per connection.
Thanks.
Thanks for your suggestion.
Can you describe us your use case?
