Topic "Allow to pass -h on the file property dialog to change the onwer:group of a symlink"
mpfrenette
When you change the owner of a symlink, it doesn't edit the owner of the symlink, but instead, the owner of the file or directory pointed to by the symlink.
In order to change the owner of the actual symlink, the chown needs to have the -H parameter passed.
When the property dialog is called on a symlink, can we have a checkbox "Edit properties of symlink" ?
Is this for the SCP protocol, I assume?
mpfrenette
Yes, for the SCP protocol, I should have specified it.
OK, thanks for your suggestion.
Will see if more people ask for this.
mpfrenette
Would a donation help Smile
Would it be OK, if WinSCP always uses -h for all symlinks? That's an easy change.
