Topic "Can't open file with long path"
Can't transfer files with long path
Can't open file 'C:\Projects\laravel\***.********-**.Com\node_modules\gulp\node_modules\gulp-util\node_modules\dateformat\node_modules\meow\node_modules\normalize-package-data\node_modules\validate-npm-package-license\node_modules\spdx-correct\node_modules\spdx-license-ids\LICENSE'.
System Error. Code: 3.
The system cannot find the path specified
Description: Can't transfer files with long path
What protocol are you using? Please attach a full session log file showing the problem (using the latest version of WinSCP).
