adding a new SSH fingerprint alongside existing one
HappyChappy
We SFTP to another client on a daily basis. They have advised that they are going to be migrating their server over a weekend and as a result their SFTP server's fingerprint will change from its current value.
They ask that the new fingerprint is added to our SFTP client's trusted key store ahead of the migration date. This will ensure that our connection is not blocked by our SFTP client when the fingerprint changes. They have supplied the new fingerprint "ssh-rsa 1024 1x:11:xx:xx:80:74:a2:c9:59:yy:bb:0p:78:d8:bd:u2"
Is there a way I can add this new fingerprint in along side the existing one so that the migration can be as seamless as possible?
HappyChappy
Chris David
Re: adding a new SSH fingerprint alongside existing one
HappyChappy
I think you have the ability to provide multiple fingerprints each needing to be separated by a semi-colon.
HappyChappy
spoke to soon:
I got error in log: Script: Unknown command '1024'
code is like:
%SECUREFTP% /log="E:\Client\Logs\test.log" /command "option batch abort" "open -timeout=60 sftp://Username:Password@111.111.111.1:22/test/ -hostkey="ssh-rsa 1024 x2:v4:n6:f8:z1:c3:65:77:45:32:98:8b:7b:09:9j:s0";"ssh-rsa 1024 g5:v4:n6:p8:z1:c3:88:77:45:xj:98:8b:7b:h9:9j:s0"" "put -transfer=ascii -nopreservetime -nopermissions -delete "E:\Host\Primary\Test\fingerprinttest.csv"" "exit"
Chris David
HappyChappy wrote:
spoke to soon:
code is like:
As mentioned, each fingerprint needs to be separated by a semi-colon, but the ENTIRE set of fingerprints only requires one open and one close quote.
It should look something like this (where key#1 and key#2 are the actual keys you wanted to use):
"ssh-rsa 1024 key#1;ssh-rsa 1024 key#2"
HappyChappy
same error :? :(
changed code to
getting same error :? :(
changed code to
%SECUREFTP% /log="E:\Client\Logs\test.log" /command "option batch abort" "open -timeout=60 sftp://Username:Password@111.111.111.1:22/test/ -hostkey="ssh-rsa 1024 x2:v4:n6:f8:z1:c3:65:77:45:32:98:8b:7b:09:9j:s0;ssh-rsa 1024 g5:v4:n6:p8:z1:c3:88:77:45:xj:98:8b:7b:h9:9j:s0"" "put -transfer=ascii -nopreservetime -nopermissions -delete "E:\Host\Primary\Test\fingerprinttest.csv"" "exit"
& still get error
. 2016-10-13 15:40:16.994 Startup conversation with host finished.
< 2016-10-13 15:40:16.994 Script: Active session: [1] Username@111.111.111.1
> 2016-10-13 15:40:16.995 Script: 1024
< 2016-10-13 15:40:16.995 Script: Unknown command '1024'.
. 2016-10-13 15:40:16.995 Script: Failed
. 2016-10-13 15:40:16.995 Script: Exit code: 1
. 2016-10-13 15:40:16.995 Closing connection.
Chris David
HappyChappy wrote:
same error :? :(
changed code to
changed code to
& still get error
I know this doesn't solve your multiple fingerprint issue, but use the EXACT same command line, but as a test, revert to using only ONE fingerprint to see if you still have an error message.
Chris David
HappyChappy wrote:
if i take out the -hostkey"<key>;<key>" it works fine
Just to add. The web page below:
https://winscp.net/eng/docs/commandline
clearly states that it can be done:
"Parameter /hostkey specifies fingerprint of expected SSH host key (or several alternative fingerprints separated by semicolon). It makes WinSCP automatically accept host key with the fingerprint."
Your problem is most likely elsewhere in that entire command line (it doesn't look correct to me just by seeing double quotes in certain places for example).
HappyChappy
got it :)
according to the link above you posted: "any script command argument that includes spaces is expected to be surrounded by double-quotes within the command"
so I changed the code to (triple quotes in a row :) ):
%SECUREFTP% /log="E:\Client\Logs\test.log" /command "option batch abort" "open -timeout=60 sftp://Username:Password@111.111.111.1:22/test/ -hostkey=""ssh-rsa 1024 x2:v4:n6:f8:z1:c3:65:77:45:32:98:8b:7b:09:9j:s0;ssh-rsa 1024 g5:v4:n6:p8:z1:c3:88:77:45:xj:98:8b:7b:h9:9j:s0""" "put -transfer=ascii -nopreservetime -nopermissions -delete "E:\Host\Primary\Test\fingerprinttest.csv"" "exit"
and it works now!
Thanks for the pointers guys
Chris David
HappyChappy wrote:
got it :)
and it works now!
You do realize that double quotes means this -> "
It does NOT mean this -> ""
Even if the command line is working, there is still something that looks very odd about it. I don't use command line scripts for what I do, I use the NET assembly, but if you gave me a temporary username/password I would be able to figure it out. Nonetheless, if you are happy with what you have then don't worry about it. Take care.
