Topic "Invalid access to memory"
GoldenWolf
i have "Invalid access to memory" message on 3.7.6 sometime when i copy file in the same directory with other name (Shift+F5)
(error on refreshing of directory list)
Were you using some previous versions? Did you have the problem with them? How do you specify the new name? File name only, full path, operation mask? Does it make difference?
GoldenWolf
yes, i use every published version of WinSCP since 3.7.1:
3.5.6
3.7.1
3.7.4
3.7.5b
3.7.6 <= bug only in this version
bug is unstable: after it, i try again to specify new filename and all working fine; but i already has this bug 5-6 times at last 2 days (since installation of version 3.7.6)
P.S. sorry for my english Smile
GoldenWolf
today expirence: 20-30 refreshes at same directory at same time very often call this bug
I have already experienced the problem too. Thanks for pointing my attention to it.
anon
Using 3.7.6 Build 306. I get this same error when the connection is reset. The Invalid memory dialoge continues to pop-up even after clicking OK for a very annoyingly large number of times. Where do I submit a bug? How can I help?
Did you had the problem with previous releases too?
You did already Smile
duerra
I've had this problem for the last couple of releases, too. It appears to happen when a connection has somehow been severed, and WinSCP does whatever it does to re-establish that connection.
Also, if WinSCP hasn't detected a severed connection, and you try to change directories again, you'll eventually get the "15 seconds" warning, and afterwards when you try to reconnect again, the reconnect/cancel dialogue just keeps popping up until you force-kill WinSCP.
duerra wrote:
When you put everything into something, it means everything to you.
duerra
Do you have any leads on this issue? Is there anything more that I can do to help?
Note that all my problems begin once my connection gets severed somehow. It's usually a problem with our company's router.
Currently I have no clue, so I even do not know what to ask for Sad
duerra
Is there any place where this exceptions are written to file so that I could send you some sort of dump or something?
i have the same problem when i launch WinSCP3 3.7.5 and 3.7.6
I think maybe confilct to windows. I remember I use 3.7.5 with no problem first. though i don't use it very ofen, and one day, the problem appears.
Cipera
Strange is, that when i connect to my server without proxy settings, all goes fine.
As soon as i am in work, where i need proxy settings (and yes, they are corrrect) i get the following error message when i try to connect to my server..:
ERROR
Invald access to memory
Above is done all on the same laptop..
Cipera
V3.7.6, build 306
Really strange, without proxy settings it works perfect, with proxy settings i get the message.
If needed, i can e contacted on icq: 143744286
Cipera
Any suggestions...?
At home this weekend i can try the beta verison of 3.8
Maybe that helps.
Cipera wrote:
Any suggestions...?
Maybe that helps.
None yet. Neither I think that 3.8 will solve the problem Sad Well, if it is about proxy, what I do not think. I guess there is something else.
hajma
version 3.8.0 build 312; Win 2k
when I setup proxy I get the error. It goes fine without it.
What kind of proxy?
wega51
I too get the "invalid access to memory" error. It happens as after I start WinSCP and login to a session. The new 3.8 beta shows that the connection is established and when the main window tries to open (full screen), the error box appears. (The problem does not occur when the application is started not full screen.) After clicking OK, the program runs normally and no problems are encountered during the session. I had the problem with 3.7.6 and now also with the new 3.8 beta. I am running Windows XP (service pack 1) and no proxy server is set up.
Best regards,
Wega51
dodo74
I have the same problem with "invalid access to memory" while using http proxy. Without that it works just fine, but I desparately need proxy settings to access my home server from my workplace. I tested v3.7.6 and 3.8 beta.
Zaug, Janez
Can someone finally tell me, with what proxy type do you have the problems? Smile
wega51
As I said before, I am having this problem WITHOUT any proxy setup. I believe the problem is related to the fact that the window is scaled to full size. When I just stretch the window to occupy the whole screen and then close the program everything works fine after restarting. However, when I use the maximize button and close the program, the next session opens with "Invalid access to memory". I am not a skilled Windows programmer, but it looks to me that the problem is in the user interface (GUI) handling.
Best regards,
Wega51.
Definitely, there are several different bugs reported in the topic. I was referring to the one connected to proxy. Sorry for not being accurate.
ftom75
wega51 wrote:
.... I believe the problem is related to the fact that the window is scaled to full size. ...
exactly the same for me with only one extension, i'm using two screens with ultramon software and i cannot send the winscp to the other screen with no problem, because the winscp will be resized and i can only close it.
Hotzi
same problem with ultramon here, i cannot use the ultramon feature which moves a maximized windows to the next screen with WinSCP (WinSCP ist the only tool where i get this problem).
There is a screenshot with the moved WinSCP in the upper left corner:
Best regards
Hotzi
yjwong
I'm also using a proxy and I also got this error once I clicked the "Login" button. My proxy server is a HTTP proxy.
