Topic "Connection refused, again..."
uncle_george
I realize this is a standard question here, but neither the FAQ nor the search contained a solution. I get the "Network error: Connection refused" message without any other explanations. Version is 3.7.6, host is running Suse 7.3.
I have checked the following already:
- The host has no firewall at all, the Windows firewall on the client is not blocking WinSCP (even tried switching it off)
- both computers are on the same subnet connected with a simple switch
- I can perfectly connect with Putty/SSH on the same port
- I can connect on the host locally by executing "sftp localhost"
So what gives? The deamon is running on the host, the ports are open...
Here is my log:
. 2005-09-13 19:16:54.349 --------------------------------------------------------------------------
. 2005-09-13 19:16:54.349 WinSCP Version 3.7.6 (Build 306) (OS 5.1.2600 Service Pack 2)
. 2005-09-13 19:16:54.349 Login time: Dienstag, 13. September 2005 19:16:54
. 2005-09-13 19:16:54.349 Session name: root@10.11.7.101
. 2005-09-13 19:16:54.349 Host name: 10.11.7.101 (Port: 22)
. 2005-09-13 19:16:54.349 User name: root (Password: Yes, Key file: No)
. 2005-09-13 19:16:54.349 Transfer Protocol: SFTP (SCP)
. 2005-09-13 19:16:54.349 SSH protocol version: 2; Compression: No
. 2005-09-13 19:16:54.349 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2005-09-13 19:16:54.349 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2005-09-13 19:16:54.349 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2005-09-13 19:16:54.349 SSH Bugs: -,-,-,-,-,-,-,-
. 2005-09-13 19:16:54.349 SFTP Bugs: -,-,-
. 2005-09-13 19:16:54.349 Proxy: none
. 2005-09-13 19:16:54.349 Return code variable: Autodetect; Lookup user groups: Yes
. 2005-09-13 19:16:54.349 Shell: /bin/bash, EOL: 0
. 2005-09-13 19:16:54.349 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2005-09-13 19:16:54.349 Cache directory changes: Yes, Permanent: Yes
. 2005-09-13 19:16:54.349 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2005-09-13 19:16:54.349 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2005-09-13 19:16:54.349 Looking up host "10.11.7.101"
. 2005-09-13 19:16:54.349 Connecting to 10.11.7.101 port 22
. 2005-09-13 19:16:55.412 Failed to connect to 10.11.7.101: Network error: Connection refused
. 2005-09-13 19:16:55.412 Attempt to close connection due to fatal exception:
* 2005-09-13 19:16:55.412 Network error: Connection refused
. 2005-09-13 19:16:55.412 Closing connection.
* 2005-09-13 19:16:55.412 (ESshFatal) Network error: Connection refused
uncle_george
Oops, host is running 9.3, not 7.3, of course.
Does the connection reach the server?
Mark_G
I've the same problem.
Three months ago everything works fine. Now this error.
Server is SUSE 9.2 with ip-adres 192.168.1.99.
Log file is :
. 2005-09-20 13:10:32.296 Looking up host "192.168.1.99"
. 2005-09-20 13:10:32.296 Connecting to 192.168.1.99 port 22
. 2005-09-20 13:10:36.468 Failed to connect to 192.168.1.99: Network error: Connection refused
. 2005-09-20 13:10:36.468 Attempt to close connection due to fatal exception:
* 2005-09-20 13:10:36.468 Network error: Connection refused
. 2005-09-20 13:10:36.468 Closing connection.
* 2005-09-20 13:10:36.484 (ESshFatal) Network error: Connection refused
Ping works fine :
C:\Documents and Settings\EMS_Consult>ping 192.168.1.99
Pingen naar 192.168.1.99 met 32 byte gegevens:
Antwoord van 192.168.1.99: bytes=32 tijd<1 ms TTL=64
Ping-statistieken voor 192.168.1.99:
Pakketten: verzonden = 4, ontvangen = 4, verloren = 0
(0% verlies).De gemiddelde tijd voor het uitvoeren van n bewerking in milliseconden:
Minimum = 0ms, Maximum = 0ms, Gemiddelde = 0ms
I can start xDeep/32 and log in to the server.
Everything else also works fine.
Mark
