Topic "Files seen six hours behind"
Cris
(First of all: "server timezone offset" or "DST" didn't help)
Hi, I'm connecting to two different unix servers on my employer's network. In one of them (Production environment) I don't have write permissions, files are seen correctly. In the other (development environment) I have write permissions but files are seen with their timestamp six hours behind.
Example:
(typing on terminal software, not on WinSCP)
ls > showthetime
(creates file called showthetime)
-rw-rw-r-- 1 Cris 62 Sep 15 21:04 showthetime
but on WinSCP it shows as 15:04.
Messing with "server timezone offset" or DST settings didn't help.
Thanks a lot!!
What protocol do you use? SCP or SFTP?
Cris
From the "Server and protocol information" command (this is the server with the 6-hrs diff)
SSH Protocol version=2
SSH Implem.=OpenSSH_3.7.1p2
Encryption alg.=aes
Compression=No
File transfer prot.=SFTP (v3)
"The server does not support any SFTP extension."
(and this is the server which looks OK)
SSH Implem.=OpenSSH_3.4p1
Encryption alg.=aes
Compression=No
Also "SSH Implementation" is the difference between the two. Is there anything I could do?
Cris
Thanks. Also what is timezone of your servers (both) and your desktop?
Hi, it took a while but here is it:
Desktop: (GMT -03:00) Buenos Aires/Georgetown (Correct)
Server which looks OK:
a "echo $TZ" command yields "ARGENTINA3"
Server which looks wrong:
a "echo $TZ" command yields "GMT-3"
I don't know if I mentioned this earlier but I'm located in Argentina, Buenos Aires. (And so are all servers involved in this problem)
Greetings
Have you tried setting $TZ same on both servers?
