Topic "How to redirect terminal output of winscp3.com to file"
TN
Hello there I got a question, is it possible to redirect the output of winscp3 command shell promt into file? I would like to generate files with the content of my directories. I tried to use ls > list.txt, but it doesn't work win winscp3.com command shell. Can anybody help?
You can only redirect whole session:
Quote:
winscp.com /command "open user@host" "ls" > output.exe
Kaydet81
I am trying to call WinSCP from a Visual C++ 6 program using CreateProcess. The resultant command line is something like:
Quote:
"C:\Program Files\WinSCP3\WinSCP3.com" /script=C:\TEMP\SCR1.tmp > C:\TEMP\SCR2.tmp 2>&1
This works fine from a command prompt but does not work well from my program (with appropriate escapes for "\") or the Windows "Run" dialog. The Run dialog produces the same results as my program - I get a console window that prompts for a user name, shows some errors, and does not redirect output.
For context, my VC6 program's purpose is to get files from source control (PVCS) and push them out to the server with WinSCP in a seamless fashion. I need to capture output to know the nature of errors that may occur.
Thank you.
I'll try that. I never did.
xpcommon
i ll see it later
You need to run the command via intepreter (cmd.exe) to allow output redirection from "run" dialog.
farmerBill
winscp.com /command "..." "..." > out.txt
does not work. Any ideas?
And what does it do? Where do you run the command from?
farmerBill
(VISTA .bat file):
@echo off
start "cmd.exe /A WinSCP" "C:\Program Files\WinSCP\WinSCP.com" /command ^
"open student@localhost" ^
"cd /home/student/asas" ^
"pwd" ^
"put abc.txt" ^
"ls" ^
> hw3updat.scriptlog
farmerBill
Sorry I didn't answer your post completely. It creates an empty file. The FTP commands work ok. Same behavior with "CMD.EXE" omitted.
Omit both start and cmd.exe. This way you are redirecting output of start command, which has none.
See guide to using WinSCP from .NET.
