Topic ""Reading remote dir" - No window - process takes 99% CPU"
bkgoodman
On opening WinSCP connections to two of my machines, after login, the dialog breifly says "Reading Remote Directory" then disappears.
I see no windows, or tasbar icon.
Going into Task Manager, I see the WinSCP process taking 99% CPU, and its mem utilization infinitely climbing.
The systems it connects to are using:
OpenSSH_4.2p1, OpenSSL 0.9.7a Feb 19 2003
and
sshd version OpenSSH_3.8p1, OpenSSL 0.9.6c 21 dec 2001
How do I figure out why?
bkgoodman
Here is the session Log:
. 2005-10-04 14:22:20.726 Transfer Protocol: SFTP (SCP)
. 2005-10-04 14:22:20.726 SSH protocol version: 2; Compression: No
. 2005-10-04 14:22:20.726 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2005-10-04 14:22:20.726 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2005-10-04 14:22:20.726 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2005-10-04 14:22:20.726 SSH Bugs: -,-,-,-,-,-,-,-
. 2005-10-04 14:22:20.726 SFTP Bugs: -,-,-
. 2005-10-04 14:22:20.726 Proxy: none
. 2005-10-04 14:22:20.726 Return code variable: Autodetect; Lookup user groups: Yes
. 2005-10-04 14:22:20.726 Shell: default, EOL: 0
. 2005-10-04 14:22:20.726 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2005-10-04 14:22:20.726 Cache directory changes: Yes, Permanent: Yes
. 2005-10-04 14:22:20.726 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2005-10-04 14:22:20.726 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2005-10-04 14:22:20.726 --------------------------------------------------------------------------
. 2005-10-04 14:22:20.726 Looking up host "bkg.sytes.net"
. 2005-10-04 14:22:20.788 Connecting to 24.61.88.55 port 22
. 2005-10-04 14:22:20.929 Server version: SSH-1.99-OpenSSH_3.8p1
. 2005-10-04 14:22:20.929 We claim version: SSH-2.0-WinSCP_release_3.7.4
. 2005-10-04 14:22:20.929 Using SSH protocol version 2
. 2005-10-04 14:22:20.976 Doing Diffie-Hellman group exchange
. 2005-10-04 14:22:21.101 Doing Diffie-Hellman key exchange
. 2005-10-04 14:22:22.991 Host key fingerprint is:
. 2005-10-04 14:22:22.991 ssh-rsa 1024 db:1e:76:ee:49:ed:a8:6d:68:cf:c1:12:a7:49:b8:9d
. 2005-10-04 14:22:22.991 Initialised AES-256 client->server encryption
. 2005-10-04 14:22:22.991 Initialised HMAC-SHA1 client->server MAC algorithm
. 2005-10-04 14:22:22.991 Initialised AES-256 server->client encryption
. 2005-10-04 14:22:22.991 Initialised HMAC-SHA1 server->client MAC algorithm
! 2005-10-04 14:22:23.038 Using username "bkg".
. 2005-10-04 14:22:23.038 Reading private key file "C:\Documents and Settings\bgoodman\My Documents\Putty Keys\usb2.ppk"
. 2005-10-04 14:22:23.069 Offered public key
. 2005-10-04 14:22:23.194 Offer of public key accepted
! 2005-10-04 14:22:23.194 Authenticating with public key "usbkey2 [2048-bit dsa, bgoodman@BGOODMAN-PC1, Fri Apr 29 2005 20:40:50]"
. 2005-10-04 14:22:23.194 Passphrase prompt (Passphrase for key "usbkey2 [2048-bit dsa, bgoodman@BGOODMAN-PC1, Fri Apr 29 2005 20:40:50]": )
. 2005-10-04 14:22:26.413 Access granted
. 2005-10-04 14:22:26.429 Opened channel for session
. 2005-10-04 14:22:26.476 Started a shell/command
. 2005-10-04 14:22:26.476 --------------------------------------------------------------------------
. 2005-10-04 14:22:26.476 Using SFTP protocol.
. 2005-10-04 14:22:26.476 Doing startup conversation with host.
> 2005-10-04 14:22:26.476 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2005-10-04 14:22:26.726 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2005-10-04 14:22:26.726 SFTP version 3 negotiated.
> 2005-10-04 14:22:26.726 Type: SSH_FXP_EXTENDED, Size: 38, Number: 200
< 2005-10-04 14:22:26.773 Type: SSH_FXP_STATUS, Size: 38, Number: 200
< 2005-10-04 14:22:26.773 Status/error code: 8
. 2005-10-04 14:22:26.773 Server does not recognise WinSCP.
. 2005-10-04 14:22:26.773 We believe the server has signed timestamps bug
. 2005-10-04 14:22:26.773 Getting current directory name.
. 2005-10-04 14:22:26.773 Getting real path for '.'
> 2005-10-04 14:22:26.773 Type: SSH_FXP_REALPATH, Size: 10, Number: 528
< 2005-10-04 14:22:26.788 Type: SSH_FXP_NAME, Size: 39, Number: 528
. 2005-10-04 14:22:26.788 Real path is '/home/bkg'
. 2005-10-04 14:22:26.788 Listing directory "/home/bkg".
> 2005-10-04 14:22:26.788 Type: SSH_FXP_OPENDIR, Size: 18, Number: 779
< 2005-10-04 14:22:26.819 Type: SSH_FXP_HANDLE, Size: 13, Number: 779
> 2005-10-04 14:22:26.819 Type: SSH_FXP_READDIR, Size: 13, Number: 1036
< 2005-10-04 14:22:27.163 Type: SSH_FXP_NAME, Size: 7017, Number: 1036
> 2005-10-04 14:22:27.163 Type: SSH_FXP_READDIR, Size: 13, Number: 1292
< 2005-10-04 14:22:27.194 Type: SSH_FXP_STATUS, Size: 28, Number: 1292
< 2005-10-04 14:22:27.194 Status/error code: 1
> 2005-10-04 14:22:27.194 Type: SSH_FXP_CLOSE, Size: 13, Number: 1540
. 2005-10-04 14:22:27.194 Startup conversation with host finished.
Please, give me contact to you, so I can send you a debug version.
