Topic "Unrequired editors selection (Internal/external)"
Alain
Hi Martin,
I use your full featured last version of WinSCP 3.7.6 (build 306) with the SFTP protocol.
One of these features is a simple internal editor.
It seems that this editor is activated automatically even when not required.
I have try configuration to disable (perhaps temporarily) this, as I need to use UltraEdit, an external editor:
I observe the following behaviour, depending perhaps from the file extension, whatever the configuration is:
sendmail-timeout.cf => external editor (as selected)
virtusertable => internal editor (unrequired)
What is my mistake Embarassed or what I can do Idea to by-pass this ?
Thanks Martin for your very nice software, and you support for many years,
Alain
I guess that it is the empty autoselection mask that causes you problem. Try to specify "*.*".
Alain
In fact it was formely "*.*" but with the trouble I pointed out, so I try the empty selection which still don't work.
Nevertheless you are right Martin but it is (a very little) more complex Wink. Your answer encourage me to test "*.*; *" with the right behavior Smile
To share experience may I try to put this in doc ?
Thanks for your help,
Alain
It seems rather like a bug. So please, do not put it into documentation Smile
Also mask "*" should be enough.
Alain
Perfectly right, Martin, it works. May be this mask "*" can be the default value for the external editor choice.
Thanks again,
Alain
