Topic "Problem with keepuptodate command line..."
Cyprien
I use winscp 3.7.6
i've write a small script :
option batch on
open root:admin@192.168.0.1:222
cd /root
option transfer automatic
option
keepuptodate c:\cynet /root/cynet
close
When i run it with the command line :
winscp3 /console /script=cynet.txt
I get :
C:\Program Files\WinSCP3>winscp3 /console /script=cynet.txt
batch on
confirm off
Initialisation...
Searching for host...
Connecting to host...
Authenticating...
Using username "root".
Authenticated.
Starting the session...
Reading remote directory...
Session started.
Active session: [1] root@192.168.0.1
/root
transfer automatic
batch on
confirm off
transfer automatic
synchdelete on
Watching for changes, press Ctrl-C to abort...
Scanning 'c:\cynet' for subdirectories...
Watching for changes in 3 directories...
And it stops forever at this line... Sad
Thanx for your help...
Yes, that's what it should do Smile Please read documentation. Maybe you wanted to use "synchronize" instead.
Cyprien
I'm confuse... Thank you for the answer !! Embarassed
I'm confused Smile Do you need anything more, or was my answer enough?
