Topic "WinSCP Hangs"
Pentad
Hello all!
Well, I'm new to WinSCP but I'm having a problem connecting to a site. I am trying to connect to ipaq3.handhelds.org. Its a free collection of terminals running Linux on Ipaqs and I can compile code without having a cross-dev setup on my home box. You can see their homepage here: <invalid link removed>. I actually have a Zaurus 5500 but I can compile here and run the code on my Z.
Here is my system:
1.1 Ghz P3
512k of mem
Windows XP w/sp1 and all hotfixes
I can ftp/telnet et all out to the net through my cable modem.
When I try to connect to ipaq3.handhelds.org with a username of guest and no password it does this:
Looking for host
Connecting to host
Starting Session
then it never returns. No error, no BSOD no nothing. I have to end the task as its 'not responding'. I can start WinSCP over again but its just the same.
Now there are a lot of files in the root dir of this host. I'm thinking that maybe thats the problem.
Any help you could pass along would be great!
Thanks!!
-P
Update:
I turned on the log and it went pretty far but became slower and slower until I get a quick "abnormal termination error" and everything closed.
Here is the log:
. WinSCP Version 2.0.0 (Build 93)
. Login time: Thursday, March 20, 2003 9:46:55 PM
. Session name: guest@ipaq3.handhelds.org
. Host name: ipaq3.handhelds.org (Port: 22)
. User name: guest (Password: No, Key file: No)
. SSH protocol version: 1; Compression: No
. Agent forwarding: No; TIS/CryptoCard authentication: No
. Imitate SSH2 MAC bug: No; Cipher: 3des
. Ping interval: 0 min (0 = off)
. Shell: default, EOL: 0
. Local directory: default, Remote directory: home
. Clear aliases: Yes, Unset nat.vars: Yes
. Server version: SSH-1.99-OpenSSH_3.4p1 Debian 1:3.4p1-4
. We claim version: SSH-1.5-PuTTY
. Using SSH protocol version 1
. Received public keys
. Host key fingerprint is:
. 1024 e0:ca:e9:72:33:31:82:63:a7:6c:de:5b:1d:e8:88:89
. Encrypted session key
. Using 3DES encryption
. Trying to enable encryption...
. Initialised triple-DES client->server encryption
. Initialised triple-DES server->client encryption
. Successfully started encryption
. Sent username "guest"
. Authentication successful
. Started session
. Doing startup conversation with host (shell).
> echo "WinSCP: this is end-of-file:0"
! stdin: is not a tty
< WinSCP: this is end-of-file:0
. Detecting variable containing return code of last command.
. Trying "$status".
> echo "$status" ; echo "WinSCP: this is end-of-file:0"
. Trying "$?".
> echo "$?" ; echo "WinSCP: this is end-of-file:0"
< 0
. Return code variable "$?" selected.
. Looking up current user groups.
> groups ; echo "WinSCP: this is end-of-file:$?"
< users
. Following groups found:
. users
. Clearing all aliases.
> unalias "echo" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 5: unalias: echo: not found
< WinSCP: this is end-of-file:1
> unalias "pwd" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 6: unalias: pwd: not found
> unalias "cd" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 7: unalias: cd: not found
> unalias "ls" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 8: unalias: ls: not found
> unalias "groups" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 9: unalias: groups: not found
> unalias "scp" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 10: unalias: scp: not found
> unalias "rm" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 11: unalias: rm: not found
> unalias "mv" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 12: unalias: mv: not found
> unalias "mkdir" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 13: unalias: mkdir: not found
> unalias "chmod" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 14: unalias: chmod: not found
> unalias "chgrp" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 15: unalias: chgrp: not found
> unalias "chown" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 16: unalias: chown: not found
> unalias "unset" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 17: unalias: unset: not found
> unalias "unalias" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 18: unalias: unalias: not found
> unalias "alias" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 19: unalias: alias: not found
. Clearing national user variables.
> unset "LANG" ; echo "WinSCP: this is end-of-file:$?"
> unset "LANGUAGE" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_CTYPE" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_COLLATE" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_MONETARY" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_NUMERIC" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_TIME" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_MESSAGES" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_ALL" ; echo "WinSCP: this is end-of-file:$?"
> unset "HUMAN_BLOCKS" ; echo "WinSCP: this is end-of-file:$?"
> pwd ; echo "WinSCP: this is end-of-file:$?"
< /home/guest
. Listing current directory.
> ls -la ; echo "WinSCP: this is end-of-file:$?"
< total 99284
< drwxr-xr-x 1003 guest users 65536 Mar 20 21:25 .
< drwxr-xr-x 226 root root 4096 Mar 17 09:22 ..
< drwxrwxr-x 3 guest users 4096 Jan 30 20:14 ...
< -rw-r--r-- 1 guest users 11 May 25 2002 .0verkill
< drwx------ 2 guest users 4096 Dec 29 20:29 .BitchX
< lrwxrwxrwx 1 guest users 54 Aug 8 2002 .DCOPserver_ipaq7_polaris.astro.ufl.edu:13 -> /home/guest/.DCOPserver_ipaq7_polaris.astro.ufl.edu_13
< -rw-r--r-- 1 guest users 52 Aug 8 2002 .DCOPserver_ipaq7_polaris.astro.ufl.edu_13
< -rw------- 1 guest users 12288 Jan 23 2001 .L3125-8TMP.htmlL3125-8TMP.html.swp
< -rw------- 1 guest users 32 Nov 27 19:06 .MCOP-random-seed
< -rw------- 1 guest users 1907 Mar 19 17:10 .Xauthority
< -rw-r--r-- 1 guest users 571 Feb 10 2001 .YSM-cfg
< -rw-r--r-- 1 guest users 0 Nov 28 17:58 .addressbook
< -rw------- 1 guest users 2285 Nov 28 17:58 .addressbook.lu
< drwx------ 2 guest users 4096 Dec 1 12:23 .adonthell
< drwxr-xr-x 2 guest users 4096 Nov 28 23:42 .advance
< -rw-r--r-- 1 guest users 2094 Mar 28 2001 .aerc
< drwx------ 4 guest users 4096 Nov 11 2001 .angband
< -rw-r--r-- 1 guest users 140 May 24 2001 .appletviewer
< -rw-r--r-- 1 guest users 10 Feb 12 12:45 .ash_history
< -rw------- 1 guest users 6539 Mar 20 21:44 .bash_history
< -rw------- 1 guest users 0 Feb 19 01:46 .bash_history.save
< lrwxrwxrwx 1 guest users 8 Aug 21 2002 .bash_profile -> .profile
< -rw-r--r-- 1 guest users 650 Sep 25 11:55 .bashrc
< -rw-r--r-- 1 guest users 499 Mar 13 2002 .bashrc.~1~
< -rw-r--r-- 1 guest users 267 Aug 12 2002 .basilisk_ii_prefs
< drwxr-xr-x 2 guest users 4096 Sep 24 14:31 .beaver
< -rw-r--r-- 1 guest users 1018 Mar 4 2001 .blackboxrc
< drwxr-xr-x 2 guest users 4096 Feb 3 11:07 .ccache
< drwx------ 2 guest users 4096 Dec 10 19:41 .cedit
< drwxr-xr-x 6 guest users 4096 Nov 12 16:07 .cpan
< -rw-r--r-- 1 guest users 15 Nov 24 13:53 .cshrc
< -rw------- 1 guest users 7876 Mar 18 09:48 .cvspass
< drwx------ 2 guest users 4096 Mar 17 02:41 .dbus-keyrings
< -rw-r--r-- 1 guest users 637 Mar 3 2001 .designerrc
< -rw-r--r-- 1 guest users 968 Mar 3 2001 .designerrctb
< -rw-r--r-- 1 guest users 941 Mar 31 2002 .emacs
< drwxr-xr-x 3 guest users 4096 Mar 16 2001 .emacs.d
< -r-------- 1 guest users 20 Jan 3 2001 .erlang.cookie
< -r--r--r-- 1 guest users 7007 May 30 2002 .fishsrv.pl
< drwxr-xr-x 3 guest users 4096 Jun 24 2002 .fltk
< drwx------ 3 guest users 4096 Sep 26 2001 .freesci
< -rw------- 1 guest users 1203 Feb 24 18:19 .gaimrc
< drwx------ 3 guest users 4096 Mar 16 21:00 .gconf-dbus
< drwx------ 2 guest users 4096 Mar 16 20:58 .gconfd-dbus
< drwx------ 3 guest users 4096 Sep 4 2001 .gnome
< drwx------ 2 guest users 4096 Sep 4 2001 .gnome_private
< drwx------ 2 guest users 4096 Nov 11 07:12 .gnupg
< -rw-r--r-- 1 guest users 58 Mar 10 2001 .gnut_hosts
< -rw-r--r-- 1 guest users 636 Mar 10 2001 .gnutrc
< lrwxrwxrwx 1 guest users 35 Nov 6 2001 .gpsdrive -> ganter@ganter.at/gpsdrive-0.18/src/
< -rw-r--r-- 1 guest users 107 Feb 19 01:45 .grassrc5
< -rw------- 1 guest users 0 Sep 17 2002 .hilfe_history
< drwxr-xr-x 2 guest users 4096 Nov 29 20:38 .hmm
< -rw-r--r-- 1 guest users 16 Jul 2 2002 .hushlogin
< -rw-r--r-- 1 guest users 44 Oct 17 2001 .ivox4rc
< -rw-r--r-- 1 guest users 21783 Apr 22 2001 .jmf-resource
< -rw-r--r-- 1 guest users 17179 Nov 6 2000 .joerc
< drwx------ 4 guest users 4096 Aug 5 2002 .licq
< drwx------ 2 guest users 4096 Mar 5 16:30 .links
< -rw------- 1 guest users 1324 Mar 8 20:25 .lynx_cookies
< -rw------- 1 guest users 14327 Dec 15 20:00 .lynxrc
< -rw-r--r-- 1 guest users 3283 Nov 15 2001 .mbscore
< -rw------- 1 guest users 147 May 21 2001 .mbus
< drwxr-xr-x 2 guest users 4096 Mar 17 11:31 .mc
< drwxr-xr-x 2 guest users 4096 Nov 15 02:31 .mplayer
< drwxr-xr-x 2 guest users 4096 Mar 19 00:35 .ncftp
< drwx------ 2 guest users 4096 Jul 22 2002 .nutdb
< -rw------- 1 guest users 9689 Oct 24 12:22 .pine-debug1
< -rw------- 1 guest users 9929 Apr 16 2002 .pine-debug2
< -rw------- 1 guest users 20265 Jan 16 2001 .pine-debug3
< -rw------- 1 guest users 9824 Oct 16 2001 .pine-debug4
< -rw-r--r-- 1 guest users 14957 Feb 3 14:38 .pinerc
< -rw-r--r-- 1 guest users 39 Oct 16 20:22 .pong_curses_prefs
< drwx------ 6 guest users 4096 Feb 3 06:04 .ppxp
< -rw-r--r-- 1 guest root 419 Aug 13 2002 .profile
< drwxr-xr-x 4 guest users 4096 Mar 18 2002 .quakeforge
< -rw-r--r-- 1 guest users 119 Feb 5 14:12 .rhosts
< -rw-r--r-- 1 guest users 53 Dec 12 05:32 .root_hist
< drwxr-xr-x 2 guest users 4096 Nov 2 01:25 .rpc
< -rw-r--r-- 1 guest users 27927 Jan 3 2002 .rpmmacros
< -rw-r--r-- 1 guest users 8230 Mar 5 2001 .rpmmacros.old
< -rw-r--r-- 1 guest users 9770 Jan 3 2002 .rpmrc
< -rw-r--r-- 1 guest users 186 Jul 25 2001 .saves-10009-skiffcluster2.handhelds.org~
< -rw-r--r-- 1 guest users 76 Jun 20 2001 .saves-1027-skiffcluster1.handhelds.org~
< -rw-r--r-- 1 guest users 220 Apr 19 2002 .saves-10594-tigershark.handhelds.org~
< -rw-r--r-- 1 guest users 88 Nov 9 21:38 .saves-10913-skiffcluster3.handhelds.org~
< -rw-r--r-- 1 guest users 106 Sep 12 2001 .saves-11578-skiffcluster1.handhelds.org~
< -rw-r--r-- 1 guest users 156 May 11 2002 .saves-11814-skiffcluster1.handhelds.org~
< -rw-r--r-- 1 guest users 134 Feb 26 2002 .saves-11867-skiffcluster1.handhelds.org~
< -rw-r--r-- 1 guest users 78 Feb 19 2001 .saves-11915-skiffcluster2.handhelds.org~
< -rw-r--r-- 1 guest users 46 Feb 5 2001 .saves-1220-skiffcluster1.handhelds.org~
< -rw-r--r-- 1 guest users 110 Apr 7 2002 .saves-12431-skiffcluster1.handhelds.org~
< -rw-r--r-- 1 guest users 176 Apr 20 2002 .saves-12620-skiffcluster3.handhelds.org~
< -rw-r--r-- 1 guest users 78 Mar 28 2002 .saves-1299-skiffcluster2.handhelds.org~
< -rw-r--r-- 1 guest users 98 Nov 23 14:05 .saves-13326-ipaq6.handhelds.org~
< -rw-r--r-- 1 guest users 92 Nov 27 2001 .saves-13522-skiffcluster4.handhelds.org~
< -rw-r--r-- 1 guest users 462 Jun 26 2002 .saves-13906-skiffcluster1.handhelds.org~
< -rw-r--r-- 1 guest users 0 Dec 29 12:30 .saves-15251-ipaq4.handhelds.org~
< -rw-r--r-- 1 guest users 96 Dec 19 2001 .saves-15350-skiffcluster5.handhelds.org~
< -rw-r--r-- 1 guest users 210 Aug 14 2001 .saves-16143-skiffcluster1.handhelds.org~
< -rw-r--r-- 1 guest users 74 May 26 2002 .saves-1617-tigershark.handhelds.org~
< -rw-r--r-- 1 guest users 148 Mar 28 2002 .saves-1667-skiffcluster2.handhelds.org~
< -rw-r--r-- 1 guest users 224 Aug 3 2002 .saves-16824-skiffcluster1.handhelds.org~
< -rw-r--r-- 1 guest users 138 Aug 30 2002 .saves-16886-skiffcluster1.handhelds.org~
< -rw-r--r-- 1 guest users 1684 May 11 2002 .saves-17053-skiffcluster1.handhelds.org~
< -rw-r--r-- 1 guest users 0 Dec 29 2001 .saves-17203-skiffcluster3.handhelds.org~
< -rw-r--r-- 1 guest users 0 Feb 25 18:22 .saves-17924-skiffcluster2.handhelds.org~
< -rw-r--r-- 1 guest users 120 Feb 25 18:22 .saves-17992-skiffcluster2.handhelds.org~
< -rw-r--r-- 1 guest users 370 Mar 28 2002 .saves-18097-skiffcluster4.handhelds.org~
< -rw-r--r-- 1 guest users 142 Mar 26 2002 .saves-18215-skiffcluster2.handhelds.org~
< -rw-r--r-- 1 guest users 110 Apr 2 2002 .saves-18308-tigershark.handhelds.org~
< -rw-r--r-- 1 guest users 110 Apr 2 2002 .saves-18849-tigershark.handhelds.org~
< -rw-r--r-- 1 guest users 130 Mar 19 11:42 .saves-18911-ipaq3.handhelds.org~
< -rw-r--r-- 1 guest users 94 Nov 11 01:00 .saves-19329-ipaq4.handhelds.org~
< -rw-r--r-- 1 guest users 116 Apr 2 2002 .saves-19451-tigershark.handhelds.org~
< -rw-r--r-- 1 guest users 116 Apr 2 2002 .saves-19538-tigershark.handhelds.org~
< -rw-r--r-- 1 guest users 104 Apr 2 2002 .saves-19626-tigershark.handhelds.org~
< -rw-r--r-- 1 guest users 572 Mar 12 18:17 .saves-19862-ipaq3.handhelds.org~
< -rw-r--r-- 1 guest users 110 Jan 24 10:40 .saves-19936-ipaq4.handhelds.org~
< -rw-r--r-- 1 guest users 254 Feb 26 05:24 .saves-20051-ipaq3.handhelds.org~
< -rw-r--r-- 1 guest users 116 May 20 2002 .saves-20104-ipaq4.handhelds.org~
< -rw-r--r-- 1 guest users 396 Jul 17 2002 .saves-20106-skiffcluster1.handhelds.org~
< -rw-r--r-- 1 guest users 40 Dec 17 16:29 .saves-2038-ipaq3.handhelds.org~
< -rw-r--r-- 1 guest users 0 Jan 1 13:12 .saves-20598-ipaq4.handhelds.org~
< -rw-r--r-- 1 guest users 144 Mar 12 2002 .saves-20732-skiffcluster5.handhelds.org~
< -rw-r--r-- 1 guest users 98 Apr 4 2002 .saves-21095-tigershark.handhelds.org~
< -rw-r--r-- 1 guest users 104 Jun 7 2002 .saves-21891-ipaq4.handhelds.org~
< -rw-r--r-- 1 guest users 290 Jul 8 2002 .saves-22391-skiffcluster3.handhelds.org~
< -rw-r--r-- 1 guest users 70 Jun 25 2001 .saves-22394-skiffcluster1.handhelds.org~
< -rw-r--r-- 1 guest users 76 Jun 20 2001 .saves-22646-skiffcluster5.handhelds.org~
< -rw-r--r-- 1 guest users 92 Mar 29 2001 .saves-2316-skiffcluster1.handhelds.org~
< -rw-r--r-- 1 guest users 170 Aug 3 2002 .saves-23352-skiffcluster2.handhelds.org~
< -rw-r--r-- 1 guest users 338 Aug 3 2002 .saves-23403-skiffcluster2.handhelds.org~
< -rw-r--r-- 1 guest users 42 Aug 6 2002 .saves-23519-ipaq3.handhelds.org~
< -rw-r--r-- 1 guest users 432 Jul 20 2001 .saves-23605-skiffcluster1.handhelds.org~
< -rw-r--r-- 1 guest users 88 May 23 2002 .saves-23676-skiffcluster6.handhelds.org~
< -rw-r--r-- 1 guest users 1070 Mar 30 2001 .saves-2378-skiffcluster2.handhelds.org~
< -rw-r--r-- 1 guest users 230 Jul 20 2001 .saves-23801-skiffcluster1.handhelds.org~
< -rw-r--r-- 1 guest users 110 Apr 10 2002 .saves-23917-tigershark.handhelds.org~
< -rw-r--r-- 1 guest users 0 Mar 15 2002 .saves-24015-skiffcluster1.handhelds.org~
< -rw-r--r-- 1 guest users 182 Sep 24 19:40 .saves-24034-skiffcluster3.handhelds.org~
< -rw-r--r-- 1 guest users 98 Sep 9 2002 .saves-24469-reefshark.handhelds.org~
< -rw-r--r-- 1 guest users 104 Jan 23 2001 .saves-24598-skiffcluster4.handhelds.org~
< -rw-r--r-- 1 guest users 76 Jun 21 2002 .saves-24746-ipaq5.handhelds.org~
< -rw-r--r-- 1 guest users 140 Feb 11 2001 .saves-2532-skiffcluster1.handhelds.org~
< -rw-r--r-- 1 guest users 0 May 10 2002 .saves-26326-skiffcluster1.handhelds.org~
< -rw-r--r-- 1 guest users 0 Aug 1 2002 .saves-26728-skiffcluster2.handhelds.org~
< -rw-r--r-- 1 guest users 94 Dec 14 15:07 .saves-26967-ipaq4.handhelds.org~
< -rw-r--r-- 1 guest users 112 Mar 26 2002 .saves-27105-skiffcluster2.handhelds.org~
< -rw-r--r-- 1 guest users 82 Feb 11 18:01 .saves-27635-skiffcluster3.handhelds.org~
< -rw-r--r-- 1 guest users 88 Mar 4 2002 .saves-29078-skiffcluster4.handhelds.org~
< -rw-r--r-- 1 guest users 0 Mar 19 2002 .saves-29320-skiffcluster1.handhelds.org~
< -rw-r--r-- 1 guest users 120 Feb 21 2001 .saves-2934-skiffcluster5.handhelds.org~
< -rw-r--r-- 1 guest users 64 Aug 2 2001 .saves-2937-skiffcluster4.handhelds.org~
< -rw-r--r-- 1 guest users 128 Mar 20 18:01 .saves-29861-skiffcluster3.handhelds.org~
< -rw-r--r-- 1 guest users 116 Nov 26 02:43 .saves-29863-skiffcluster2.handhelds.org~
< -rw-r--r-- 1 guest users 108 Mar 27 2002 .saves-30083-skiffcluster5.handhelds.org~
< -rw-r--r-- 1 guest users 0 Mar 3 18:34 .saves-30750-skiffcluster2.handhelds.org~
< -rw-r--r-- 1 guest users 0 Mar 3 18:34 .saves-30757-skiffcluster2.handhelds.org~
< -rw-r--r-- 1 guest users 110 Apr 10 2002 .saves-30803-tigershark.handhelds.org~
< -rw-r--r-- 1 guest users 0 Mar 3 18:34 .saves-30820-skiffcluster2.handhelds.org~
< -rw-r--r-- 1 guest users 0 Mar 3 18:34 .saves-30827-skiffcluster2.handhelds.org~
< -rw-r--r-- 1 guest users 298 Jul 13 2002 .saves-31220-ipaq5.handhelds.org~
< -rw-r--r-- 1 guest users 130 Jan 16 18:46 .saves-3644-skiffcluster1.handhelds.org~
< -rw-r--r-- 1 guest users 92 Aug 10 2002 .saves-3744-skiffcluster1.handhelds.org~
< -rw-r--r-- 1 guest users 414 Jul 1 2002 .saves-420-skiffcluster4.handhelds.org~
< -rw-r--r-- 1 guest users 146 Nov 7 13:34 .saves-4349-ipaq4.handhelds.org~
< -rw-r--r-- 1 guest users 130 Jan 16 21:15 .saves-4394-skiffcluster1.handhelds.org~
< -rw-r--r-- 1 guest users 332 Jun 14 2002 .saves-4402-ipaq7.handhelds.org~
< -rw-r--r-- 1 guest users 54 Mar 26 2002 .saves-4438-skiffcluster3.handhelds.org~
< -rw-r--r-- 1 guest users 154 Jan 28 16:03 .saves-522-ipaq4.handhelds.org~
< -rw-r--r-- 1 guest users 86 Apr 15 2002 .saves-5591-skiffcluster3.handhelds.org~
< -rw-r--r-- 1 guest users 472 Mar 3 07:30 .saves-5632-ipaq6.handhelds.org~
< -rw-r--r-- 1 guest users 104 Jan 23 04:59 .saves-5863-ipaq4.handhelds.org~
< -rw-r--r-- 1 guest users 186 Jul 23 2001 .saves-613-skiffcluster4.handhelds.org~
< -rw-rw-r-- 1 guest users 112 Dec 11 02:22 .saves-6736-skiffcluster2.handhelds.org~
< -rw-r--r-- 1 guest users 242 Apr 29 2002 .saves-6802-skiffcluster2.handhelds.org~
< -rw-r--r-- 1 guest users 86 Apr 29 2002 .saves-6887-skiffcluster2.handhelds.org~
< -rw-r--r-- 1 guest users 80 Oct 14 02:37 .saves-7129-skiffcluster6.handhelds.org~
< -rw-r--r-- 1 guest users 76 Jun 19 2001 .saves-7222-skiffcluster5.handhelds.org~
< -rw-r--r-- 1 guest users 42 Mar 26 2002 .saves-7278-skiffcluster4.handhelds.org~
< -rw-r--r-- 1 guest users 56 Feb 15 2001 .saves-7296-skiffcluster1.handhelds.org~
< -rw-r--r-- 1 guest users 2168 Mar 29 2001 .saves-733-skiffcluster2.handhelds.org~
< -rw-r--r-- 1 guest users 92 Nov 23 02:06 .saves-7417-ipaq6.handhelds.org~
< -rw-r--r-- 1 guest users 144 Jul 17 2002 .saves-7509-skiffcluster1.handhelds.org~
< -rw-r--r-- 1 guest users 0 Apr 26 2002 .saves-7531-skiffcluster4.handhelds.org~
< -rw-r--r-- 1 guest users 216 Jul 9 2002 .saves-7717-skiffcluster3.handhelds.org~
< -rw-r--r-- 1 guest users 110 Apr 23 2002 .saves-773-tigershark.handhelds.org~
< -rw-r--r-- 1 guest users 154 Jan 30 15:16 .saves-7832-ipaq4.handhelds.org~
< -rw-r--r-- 1 guest users 116 Jan 24 16:13 .saves-8842-ipaq7.handhelds.org~
< -rw-r--r-- 1 guest users 0 Jan 3 2002 .saves-8845-skiffcluster2.handhelds.org~
< -rw-r--r-- 1 guest users 116 Apr 12 2002 .saves-8957-skiffcluster2.handhelds.org~
< -rw-r--r-- 1 guest users 300 Jun 25 2002 .saves-9168-ipaq5.handhelds.org~
< -rw-r--r-- 1 guest users 110 Apr 18 2002 .saves-9329-tigershark.handhelds.org~
< -rw-r--r-- 1 guest users 128 Apr 18 2002 .saves-9393-tigershark.handhelds.org~
< -rw-r--r-- 1 guest users 0 Nov 25 01:55 .saves-9434-skiffcluster2.handhelds.org~
< -rw-r--r-- 1 guest users 152 Aug 22 2001 .saves-9865-skiffcluster3.handhelds.org~
< drwxr-xr-x 2 guest users 4096 Apr 6 2001 .sc
< lrwxrwxrwx 1 guest users 7 Nov 6 2001 .so -> .so.1.0
< lrwxrwxrwx 1 guest users 7 Nov 6 2001 .so.1 -> .so.1.0
< drwx------ 2 guest users 4096 Sep 24 14:20 .spruce
< drwxr-xr-x 2 guest users 4096 Feb 7 22:03 .ssh
< -rw------- 1 guest users 12288 Jul 29 2002 .swo
< -rw------- 1 guest users 12288 Jun 24 2002 .swp
< drwxr-xr-x 2 guest users 4096 Feb 22 2001 .sys
< drwxr-xr-x 4 guest users 4096 Nov 9 2001 .terminfo
< -rw------- 1 guest users 16384 Jul 24 2001 .testidct.cc.swp
< -rw------- 1 guest users 16384 Jul 24 2001 .testiintegerdct.cc.swp
< drwx------ 6 guest users 4096 Feb 19 19:02 .tin
< -rw-r--r-- 1 guest users 295 Feb 18 2001 .todo
< drwx------ 2 guest users 4096 Mar 2 21:06 .tome
< -rw-r--r-- 1 guest users 32 Apr 3 2001 .toprc
< -rw------- 1 guest users 99 Mar 5 21:26 .tramp_history
< -rw-r--r-- 1 guest users 854 Nov 11 2001 .tvtmakerc
< drwx------ 2 guest users 4096 Sep 24 14:19 .unison
< -rw-r--r-- 1 guest users 60 Jul 15 2001 .update
< -rw------- 1 guest users 24576 Oct 4 09:24 .vacation.db
< -rw-r--r-- 1 guest users 197 Feb 5 2001 .viewmlh.txt
< drwx------ 2 guest users 4096 Mar 10 10:42 .w3m
< -rw-r--r-- 1 guest users 2377 Mar 14 2002 .wellenreiter.rc
< -rw-r--r-- 1 root users 1902 Mar 1 2001 .xftcache
< -rw-r--r-- 1 guest users 40 Sep 28 2001 .xinerc
< drwxr-xr-x 2 guest users 4096 Aug 20 2001 .xscorch
< -rw-r--r-- 1 guest users 122 Jan 12 16:19 .yacas_history
< -rw------- 1 guest users 159 Oct 25 03:35 .yahoonixrc
< drwxr-xr-x 2 guest users 4096 Nov 12 09:40 1
< drwxr-xr-x 3 guest users 4096 Sep 17 2002 13302906@sun.ac.za
< drwxr-xr-x 4 guest users 4096 Aug 3 2002 9537565@naver.com
< -rw------- 1 guest users 0 Mar 2 14:28 :file0.c
< drwxr-xr-x 34 guest users 4096 Jan 13 08:53 Admin@AntiProxy.com
< drwxr-xr-x 3 guest users 4096 Nov 29 18:33 Applications
< drwxr-xr-x 2 guest users 4096 Oct 10 2001 JL79@mit.edu
< drwxr-xr-x 2 guest users 4096 Mar 20 21:44 Jonnyphenomenon
< drwxr-xr-x 4 guest users 4096 Mar 6 08:39 Josef.Stromsky.hgf@vsb.cz
< drwxr-xr-x 3 guest users 4096 Dec 10 17:09 LarsFriedrichs@gmx.de
< drwx------ 2 guest users 4096 Mar 7 2002 Mail
< drwxr-xr-x 3 guest users 4096 Mar 6 04:37 Miroslav.Dvorak@vsb.cz
< drwxr-xr-x 7 guest users 4096 Mar 5 15:30 P.Nejedly@sh.cvut.cz
< drwxr-xr-x 3 guest users 4096 Sep 19 2002 Pike
< lrwxrwxrwx 1 guest users 41 Mar 7 21:20 Qtopia -> /home/guest/dsolomo1@maine.rr.com/Qtopia/
< drwxr-xr-x 4 guest users 4096 Nov 21 08:22 R
< drwxr-xr-x 9 guest users 4096 Jan 28 06:32 Rene@Castberg.org
< drwxr-xr-x 7 guest users 4096 Aug 10 2002 SDL
< drwxr-xr-x 7 guest users 4096 Aug 10 2002 SDL-1.2.4
< -rw-r--r-- 1 guest users 18706 Sep 2 2002 SS5.zip
< drwxr-xr-x 2 guest users 4096 Jul 3 2002 Trevor@hfxipt.ca
< drwxr-xr-x 11 guest users 4096 Apr 12 2002 William.Gacquer@laposte.net
< drwxr-xr-x 3 guest users 4096 Jan 29 15:34 X_I_X@hotmail.com
< drwxr-xr-x 3 guest users 4096 Mar 4 00:08 abhi_shek@eudoramail.com
< drwxr-xr-x 3 guest users 4096 Feb 25 17:55 adam.roberts@pnl.gov
< drwxr-xr-x 3 guest users 4096 Mar 3 16:44 adamb@agitate.org.uk
< drwxr-xr-x 59 guest users 4096 Jan 27 23:47 aff9@aber.ac.uk
< drwxr-xr-x 3 guest users 4096 Mar 12 21:25 agupta20@yahoo.com
< drwxr-xr-x 13 guest users 4096 Sep 27 19:07 ahacop@anthrotronix.com
< drwxr-xr-x 44 guest users 4096 Mar 20 13:00 ahelin@student.oulu.fi
< -rw-r--r-- 1 guest users 119160 Mar 10 17:01 airo.c
< drwxr-xr-x 4 guest users 4096 Feb 4 01:07 ajmitch@gnu.org
< drwxr-xr-x 2 guest users 4096 Nov 22 2001 ajtuomin@tml.hut.fi
< drwxr-xr-x 2 guest users 4096 May 18 2002 alan@clegg.com
< drwxr-xr-x 2 guest users 4096 Dec 14 19:36 alanh@cs.wisc.edu
< drwxr-xr-x 2 guest users 4096 Oct 23 04:39 alberjim@wanadoo.es
< drwxr-xr-x 4 guest users 4096 Mar 6 15:52 alberto@acaso.net
< drwxr-xr-x 4 guest users 4096 Oct 31 05:03 alex@ishss10.doshisha.ac.jp
< drwxr-xr-x 2 guest users 4096 Aug 16 2001 alexkan@avamax.com
< drwxr-xr-x 2 guest users 4096 Nov 22 14:11 alonl@technion.ac.il
< drwxr-xr-x 2 guest users 4096 Oct 11 11:10 alynch@sprawl.net
< drwxr-xr-x 7 guest users 4096 Sep 19 2002 amahler@sbc.edu
< drwxrwxrwx 11 guest users 4096 May 3 2002 amayc@mit.edu
< drwxr-xr-x 13 guest users 4096 Oct 26 11:15 amori@carc.aist.go.jp
< drwxr-xr-x 7 guest users 4096 Nov 28 11:48 anbe@users.sourceforge.net
< drwxr-xr-x 8 guest users 4096 Mar 17 02:20 andersca@codefactory.se
< drwxr-xr-x 2 guest users 4096 Dec 26 2001 andrew@deathkeep.com
< drwxr-xr-x 2 guest users 4096 Sep 24 01:37 andry@dstc.edu.au
< drwxr-xr-x 2 guest users 4096 Aug 7 2002 andy.qua@blueyonder.co.uk
< drwxr-xr-x 3 guest users 4096 Feb 13 08:37 anna@netsoc.ucd.ie:
< drwxr-xr-x 2 guest users 4096 Aug 20 2002 antoni@galileo.edu
< drwxr-xr-x 2 guest users 4096 Oct 14 16:14 anwe3675@student.uu.se
< drwxr-xr-x 4 guest users 4096 Feb 28 17:52 aodv-uu-ub-0.6.1
< -rwxr-xr-x 1 guest users 60604 Feb 28 18:09 aodvd
< drwxr-xr-x 8 guest users 4096 Feb 13 19:58 aoshima@nal.ecl.net
< -rw-r--r-- 1 guest users 12428066 Mar 7 05:09 apa.tgz
< drwxrwxrwx 2 guest users 4096 Sep 9 2001 apkennedy@yahoo.com
< drwxr-xr-x 12 guest users 4096 Jan 22 01:11 arager@avaya.com
< drwxr-xr-x 3 guest users 4096 Feb 25 09:41 arjunrn@mit.edu
< drwxr-x--- 8 guest users 4096 Feb 21 08:48 arora@gdit.iiit.net
< drwxr-xr-x 2 guest users 4096 Aug 16 2002 ashok
< -rw-r--r-- 1 guest users 7766065 Mar 12 09:26 au_php423.tgz
< drwxr-xr-x 4 guest users 4096 Jun 7 2002 awalters@nd.edu
< drwxr-xr-x 2 guest users 4096 Aug 5 2002 awei@bcit.ca
< drwxr-xr-x 2 guest users 4096 May 9 2002 axel@snafu.de
< drwxr-xr-x 2 guest users 4096 Aug 22 2002 azaia@ingegneria.unime.it
< drwxr-xr-x 2 guest users 4096 Aug 13 2001 b.kuepper@twisd.de
< drwxr-xr-x 2 guest users 4096 Jan 24 11:23 b@b2.org
< drwxr-xr-x 3 guest users 4096 Oct 25 2001 barryf@digiserve.ie
< drwxr-xr-x 6 guest users 4096 Jan 31 05:17 bat@cwcom.net
< drwxr-xr-x 7 guest users 4096 Mar 3 2001 battlej@groove.com
< drwxr-xr-x 2 guest users 4096 Jan 24 17:25 bbb999@earthlink.net
< drwxr-xr-x 5 guest users 4096 Mar 9 15:29 bburns@cs.umass.edu
< drwxr-xr-x 3 guest users 4096 Jan 31 11:24 bchess@umich.edu
< drwxr-xr-x 2 guest users 4096 Dec 31 03:17 bchlaw
< drwxr-xr-x 2 guest users 4096 May 2 2002 bcitzim@yahoo.com
< drwxrwxrwx 2 guest users 4096 Dec 11 03:51 bdien@altern.org
< drwxr-xr-x 2 guest users 4096 Sep 13 2001 beeblebrox@softhome.net
< drwxr-xr-x 2 guest users 4096 Dec 14 12:00 bemis@iol.unh.edu
< drwxr-xr-x 3 guest users 4096 Feb 21 05:25 benoit.domingues@esial.uhp-nancy.fr
< drwxr-xr-x 2 guest users 4096 Feb 22 18:15 beppe
< drwxr-xr-x 5 guest users 4096 Jan 31 11:01 bgolden@optibrand.com
< drwxr-xr-x 2 guest users 4096 Apr 30 2002 bhaskar@arbornet.org
< drwxr-xr-x 2 guest users 4096 Mar 13 12:24 bhensch@deskmedia.com
< drwxr-xr-x 3 guest users 4096 Mar 20 09:33 bigbro@dmrt.com
< drwxr-xr-x 2 guest users 4096 Aug 8 2001 bill_whiting@bellsouth.net
< drwxr-xr-x 2 guest users 4096 Feb 11 22:10 bin
< drwxr-xr-x 2 guest users 4096 Mar 9 20:10 binz@usc.edu
< drwxr-xr-x 2 guest users 4096 Oct 25 2001 bisp@poune.com
< drwxr-xr-x 2 guest users 4096 Nov 16 2001 biz@trigon.net
< drwxrwxrwx 3 guest users 4096 Nov 4 16:57 bjansen@fh-landshut.de
< drwxr-xr-x 4 guest users 4096 Jan 2 15:50 bjoern@daehn-online.net
< drwxr-xr-x 6 guest users 4096 Jul 12 2002 bjoern@dagobah.in-berlin.de
< -rw-r--r-- 1 guest users 869625 Dec 20 08:16 blackdown-add_1.3.1_arm.ipk
< -rw-r--r-- 1 guest users 2973 Mar 4 05:44 bluetooth.h
< -rw-r--r-- 1 guest users 3390 Mar 4 05:44 bnep.h
< drwxr-xr-x 2 guest users 4096 Oct 10 17:40 bob@cc.gatech.edu
< drwxr-xr-x 3 guest users 4096 Dec 12 21:48 bock@blacknet.de
< drwxr-xr-x 4 guest users 4096 Jul 5 2001 boes@cs.hope.edu
< drwxr-xr-x 2 guest users 4096 Jun 3 2002 boggsj@msi.umn.edu
< drwxr-xr-x 2 guest users 4096 Mar 6 17:22 boo
< drwxr-xr-x 2 guest users 4096 Oct 27 11:22 boog@woh.rr.com
< drwxr-xr-x 3 guest users 4096 Dec 1 14:03 boor@unix-ag.org
< drwxr-xr-x 3 guest users 4096 Oct 21 01:00 boris@cryptosmasher.com
< drwxr-xr-x 3 guest users 4096 Jun 15 2002 bovine@btinternet.com
< drwxr-xr-x 2 guest users 4096 Jul 23 2001 bradford@wpi.edu
< drwxr-xr-x 2 guest users 4096 Oct 9 16:57 bram@bram.be
< drwxrwxrwx 2 guest users 4096 Jul 31 2001 bram@voltone.com
< drwxr-xr-x 3 guest users 4096 Jan 9 21:22 brammp@ix.netcom.com
< drwxr-xr-x 4 guest users 4096 Oct 13 08:29 brent@phzero.net
< drwxr-xr-x 2 guest users 4096 Feb 24 00:12 brett.pentland@monash.edu
< drwxr-xr-x 8 guest users 4096 Mar 10 04:07 bricode@cse.ogi.edu
< drwxr-xr-x 7 guest users 4096 Sep 24 2001 bryan@theWorths.org
< drwxr-xr-x 11 guest users 4096 Mar 16 23:55 bsaunder2002-yahoo.com
< drwxr-xr-x 11 guest users 4096 May 25 2002 bshingar@sympatico.ca
< drwxr-xr-x 7 guest users 4096 Mar 4 17:05 build
< drwxr-xr-x 2 guest users 4096 Nov 6 16:25 bw
< drwxr-xr-x 8 guest users 4096 Jan 14 07:35 c.stevens@auckland.ac.nz
< drwxr-xr-x 5 guest users 4096 Oct 16 04:12 cala@cs.agh.edu.pl
< drwxr-xr-x 2 guest users 4096 Aug 16 2001 cartman499@aol.com
< drwxr-xr-x 2 guest users 4096 Mar 11 2002 casassov@enst.fr
< drwxr-xr-x 4 guest users 4096 Jan 14 14:51 cbiffle@safety.net
< drwxr-xr-x 3 guest users 4096 Feb 18 16:55 cchu@cs.umass.edu
< drwxr-xr-x 2 guest users 4096 Nov 22 01:15 cdowney@execpc.com
< drwxr-xr-x 2 guest users 4096 Nov 1 2001 cfrank@linuxcare.com
< drwxr-xr-x 2 guest users 4096 Feb 28 2002 cgrube1@cs.purdue.edu
< drwxr-xr-x 2 guest users 4096 Feb 19 12:58 charles
< drwxr-xr-x 2 guest users 4096 Jul 8 2002 charles@nexuslabs.com
< drwxr-xr-x 5 guest users 4096 Dec 11 00:21 charlesv@mfos.org
< drwxr-xr-x 9 guest users 4096 Dec 17 05:38 chatty@intuilab.com
< drwxr-xr-x 2 guest users 4096 Dec 3 17:29 chen0652@d.umn.edu
< drwxr-xr-x 3 guest users 4096 Nov 10 19:28 cheng_gong@yahoo.com
< drwxrwxrwx 3 guest users 4096 Nov 12 11:04 chengsolon@hotmail.com
< drwxr-xr-x 17 guest users 4096 Sep 26 04:26 chenx1977@yahoo.com
< drwxr-xr-x 2 guest users 4096 Nov 24 18:09 chg@contronix.de
< drwxr-xr-x 3 guest users 4096 Nov 18 01:45 chiacy@sinchew-i.com
< drwxr-xr-x 2 guest users 4096 Jan 16 06:40 chiccorusso@libero.it
< drwxr-xr-x 2 guest users 4096 Feb 1 2001 chief@oachkatzlschwoaf.org
< drwxr-xr-x 2 guest users 4096 Feb 4 2001 chouston@logikos.com
< lrwxrwxrwx 1 guest users 28 Feb 4 00:28 chris.white.at.team.telstra.com -> chris.white@team.telstra.com
< drwxr-xr-x 3 guest users 4096 Feb 4 01:15 chris.white@team.telstra.com
< drwxr-xr-x 2 guest users 4096 Aug 17 2002 chris@arachsys.com
< drwxr-xr-x 18 guest users 4096 Mar 17 15:29 chris@ckpt-martin.de
< drwxr-xr-x 4 guest users 4096 Jan 28 05:55 chris@collins.id.au
< drwxr-xr-x 2 guest users 4096 Jul 11 2001 chungfat@eudoramail.com
< drwxr-xr-x 2 guest users 4096 Nov 7 2001 churchb@baysidesolutions.net
< drwxr-xr-x 6 guest users 4096 Jan 3 13:50 cjjohans@cc.helsinki.fi
< drwxrwxrwx 4 guest users 4096 Oct 12 14:46 cjx@purdue.edu
< drwxr-xr-x 3 guest users 4096 Jun 26 2001 ckimboon@hotmail.com
< drwxr-xr-x 2 guest users 4096 Sep 27 11:39 ckovacs@depauw.edu
< drwxr-xr-x 2 guest users 4096 Feb 26 17:40 ckrintz@yahoo.com
< drwxr-xr-x 9 guest users 4096 Sep 1 2002 clambert@iname.com
< drwxr-xr-x 2 guest users 4096 Mar 17 05:13 claus.groeting@siemens.com
< drwxr-xr-x 2 guest users 4096 Feb 20 15:27 clay@cwebcomm.com
< drwxr-xr-x 2 guest users 4096 Jan 16 23:08 clindahl@ibt.tamu.edu
< drwxr-xr-x 8 guest users 4096 Dec 30 06:39 clm@csse.monash.edu.au
< drwxr-xr-x 3 guest users 4096 Dec 5 17:44 cloos@jhcloos.com
< drwxr-xr-x 3 guest users 4096 Mar 18 15:16 clumens@cc.gatech.edu
< drwxr-xr-x 2 guest users 4096 Aug 4 2001 clund@san.rr.com
< drwxr-xr-x 3 guest users 4096 Mar 2 14:39 cmckin1@umbc.edu
< -rw------- 1 guest users 0 Mar 2 14:13 cmckin1@umbc.edu:file.c
< -rw------- 1 guest users 0 Mar 2 14:27 cmckin1@umbc.edu:file0.c
< -rw------- 1 guest users 678267 Mar 2 14:30 cmckin1@umbc.edu:kismet-2.8.1.tar.gz
< drwxr-xr-x 3 guest users 4096 Sep 26 19:31 cmr
< drwxr-xr-x 2 guest users 4096 Feb 1 2002 cmueller@cs.uni-sb.de
< drwxr-xr-x 22 guest users 4096 Oct 17 04:37 cnnaveen_nr@yahoo.co.in
< drwxr-xr-x 9 guest users 4096 Sep 21 19:03 colin@marquardt-home.de
< -rwxr-xr-x 1 guest users 135 Feb 12 23:46 comp
< drwxr-xr-x 3 guest users 4096 Feb 13 13:59 conber@gmx.li
< drwxr-xr-x 12 guest users 4096 May 25 2002 copperd@zemos.net
< drwxr-xr-x 2 guest users 4096 Nov 15 2001 cpage@silcom.com
< drwxr-xr-x 2 guest users 4096 Nov 16 12:33 cpu-scale
< drwxr-xr-x 9 guest users 4096 Nov 28 18:02 craig@mutinyengineering.com
< drwxrwxrwx 7 guest users 4096 Mar 14 16:13 craigv@voxware.com
< drwxrwxrwx 19 guest users 4096 Nov 27 13:21 creator@inreach.com
< drwxr-xr-x 2 guest users 4096 Aug 8 2001 cres@cb.co.kr
< drwxr-xr-x 2 guest users 4096 Jan 28 2002 crichton@gimp.org
< drwxr-xr-x 2 guest users 4096 Dec 22 19:17 cronos@olimpo.homelinux.net
< drwxr-xr-x 2 guest users 4096 Jul 14 2001 crowthersl@lionlike.net
< drwxr-xr-x 4 guest users 4096 Jul 9 2001 cruxpot@hushmail.com
< drwxr-xr-x 17 guest users 4096 Jan 29 06:03 cs871269@csie.ncu.edu.tw
< drwxr-xr-x 2 guest users 4096 Nov 18 09:08 cvandeventer@wabtec.com
< drwxr-xr-x 7 guest users 4096 Mar 3 16:52 cwang63@yahoo.com
< drwxr-xr-x 4 guest users 4096 Nov 14 2001 cworth@handhelds.org
< drwxr-xr-x 2 guest users 4096 Dec 13 2001 d98he@efd.lth.se
< drwxr-xr-x 2 guest users 4096 Mar 17 06:19 dahl76
< -rw-r--r-- 1 guest users 5 Mar 17 05:44 dahl76:test
< drwxr-xr-x 2 guest users 4096 Mar 19 12:42 dan@abc.com
< drwxr-xr-x 6 guest users 4096 Nov 30 06:23 dan@hart-house.com
< drwxr-xr-x 12 guest users 4096 Nov 27 07:23 daniel.aubry@sygroup.ch
< drwxr-xr-x 4 guest users 4096 Dec 18 22:52 daniel.craig@csiro.au
< drwxr-xr-x 2 guest users 4096 Mar 7 06:18 danielrigby@fastmail.fm
< drwxr-xr-x 9 guest users 4096 Jan 19 17:50 danl@cs.umass.edu
< drwxr-xr-x 2 guest users 4096 Mar 18 12:52 danthero@personal.ro
< drwxr-xr-x 2 guest users 4096 Oct 23 2001 dantu@usc.edu
< drwxr-xr-x 5 guest users 4096 Jun 3 2002 darcop@snet.net
< drwxr-xr-x 4 guest users 4096 Nov 2 15:43 dardo@dardo.org
< drwxr-xr-x 2 guest users 4096 Feb 5 2001 darragh@olagrande.net
< drwxr-xr-x 3 guest users 4096 Oct 28 13:25 dave@bannach.ch
< drwxr-xr-x 3 guest users 4096 Sep 22 01:15 dave@daves.net
< drwxr-xr-x 2 guest users 4096 Dec 9 2001 daveb@apc.34sp.com
< drwxr-xr-x 3 guest users 4096 Oct 19 12:02 davetgra@rocketmail.com
< drwxr-xr-x 3 guest users 4096 Sep 23 22:34 david.yule@philips.com
< drwxr-xr-x 3 guest users 4096 Mar 18 09:34 david@farr.homeip.net
< drwxr-xr-x 2 guest users 4096 Dec 12 02:58 david@hedbor.org
< drwxr-xr-x 5 guest users 4096 Jan 12 15:33 david_sheffield@brown.edu
< drwxr-xr-x 2 guest users 4096 Jan 17 09:39 davidh@s3group.cz
< drwxr-xr-x 3 guest users 4096 Dec 13 09:41 dbannach@student.ethz.ch
< drwxr-xr-x 16 guest users 4096 Dec 7 2001 dbliss@u.washington.edu
< drwxr-xr-x 4 guest users 4096 Mar 22 2001 dbutter@wireless.net
< drwxr-xr-x 3 guest users 4096 Oct 9 10:56 ddnoll
< -rw------- 1 guest users 367 Feb 21 00:19 dead.letter
< drwxr-xr-x 2 guest users 4096 Aug 25 2001 dean@blackketter.com
< drwxr-xr-x 2 guest users 4096 Jan 8 01:19 dearhamn@nu.ac.za
< drwxr-xr-x 2 guest users 4096 Aug 10 2002 debug101@yahoo.com
< drwxr-xr-x 10 guest users 4096 Feb 25 14:56 deker@slackdot.org
< drwxr-xr-x 18 guest users 4096 Feb 25 2002 demo
< drwxr-xr-x 2 guest users 4096 Mar 8 20:57 derwin.mcgeary@physics.org
< drwxr-xr-x 3 guest users 4096 Dec 3 14:51 des@ma.hw.ac.uk
< drwxr-xr-x 2 guest users 4096 Oct 3 2001 dethn0d3@net-thing.net
< drwxr-xr-x 9 guest users 4096 Sep 2 2002 dev@realinfo.it
< drwxr-xr-x 2 guest users 4096 Mar 2 09:08 dffh@mail.ru
< drwxr-xr-x 2 guest users 4096 Aug 8 2001 dgottlie@crhc.uiuc.edu
< drwxr-xr-x 2 guest users 4096 Jan 27 21:17 dhruvarajs@yahoo.com
< drwxr-xr-x 2 guest users 4096 Jan 8 11:44 diegossj@mi.madritel.es
< drwxr-xr-x 2 guest users 4096 Nov 12 05:52 djs-handheld@whatcom.net
< drwxr-xr-x 4 guest users 4096 Jun 30 2001 djs55@cam.ac.uk
< drwxr-xr-x 2 guest users 4096 Jul 12 2001 dleary@ttlc.net
< drwxr-xr-x 2 guest users 4096 Oct 31 2001 dlux@kapu.hu
< drwxr-xr-x 5 guest users 4096 Aug 15 2002 doc
< drwxr-xr-x 3 guest users 4096 Mar 16 18:22 docwhat@gerf.org
< drwxr-xr-x 2 guest users 4096 Oct 25 2001 doend@diac.com
< drwxr-xr-x 2 guest users 4096 Oct 4 22:51 doly
< drwxr-xr-x 2 guest users 4096 Oct 16 12:51 dominijannir@npt.nuwc.navy.mil
< drwxr-xr-x 2 guest users 4096 Apr 2 2002 dominik@snet.net
< drwxr-xr-x 4 guest users 4096 Oct 6 00:08 donato@eecs.tulane.edu
< drwxr-xr-x 2 guest users 4096 Oct 14 21:49 dong_temp
< drwxr-xr-x 2 guest users 4096 Mar 3 16:34 doter@email.com
< -rw-r--r-- 1 guest users 5115 Mar 8 04:11 download_presentation.php?lang=en
< -rw-r--r-- 1 guest users 6040 Mar 8 04:12 download_presentation.php?lang=en&id=242
< drwxr-xr-x 11 guest users 4096 Sep 18 2002 dr@agh.edu.pl
< drwxr-xr-x 3 guest users 4096 Jan 26 21:19 dragorn@kismetwireless.net
< drwxr-xr-x 2 guest users 4096 Sep 13 2002 dreamie@surfeu.fi
< drwxr-xr-x 46 guest users 4096 Jan 28 15:31 dsolomo1@maine.rr.com
< drwxr-xr-x 2 guest users 4096 Sep 21 2001 dtaylor@cirque.com
< drwxr-xr-x 6 guest users 4096 Feb 24 23:45 dtoler@ilan.net
< drwxr-xr-x 3 guest users 4096 Jan 9 09:08 eah
< drwxr-xr-x 2 guest users 4096 Mar 16 15:10 eaja@erols.com
< drwxr-xr-x 2 guest users 4096 Aug 18 2001 ebelloti@yahoo.com
< -rw-r--r-- 1 guest users 0 Feb 15 13:47 echo
< drwxr-xr-x 2 guest users 4096 Feb 12 16:45 ed.davison@bus.utexas.edu
< drwxr-xr-x 2 guest users 4096 Dec 5 14:57 edouard.fischer@free.fr
< drwxr-xr-x 5 guest users 4096 Nov 2 11:11 edu2k@terra.com.br
< drwxr-xr-x 2 guest users 4096 Mar 17 21:34 eepness@mit.edu
< drwxr-xr-x 2 guest users 4096 Feb 12 2001 el_toamso66@hotmail.com
< drwxr-xr-x 4 guest users 4096 Dec 6 10:19 elinakam@mit.edu
< drwxr-xr-x 2 guest users 4096 Sep 21 13:51 eljofi
< drwxr-xr-x 3 guest users 4096 Feb 21 12:06 email4kai@web.de
< drwxr-xr-x 3 guest users 4096 Feb 11 05:54 email@curto.us
< drwxr-xr-x 2 guest users 4096 Sep 3 2001 enano@fi.udc.es
< drwxr-xr-x 10 guest users 4096 Nov 13 08:46 eolson@mit.edu
< drwxr-xr-x 9 guest users 4096 Nov 24 18:36 epic4-1.1.6
< drwxrwxrwx 7 guest users 4096 Aug 21 2002 erez@savan.com
< drwxr-xr-x 3 guest users 4096 Oct 7 08:17 erik@bagfors.nu
< drwxr-xr-x 2 guest users 4096 Dec 5 2001 erik@karlberg.org
< drwxr-xr-x 2 guest users 4096 Feb 10 01:58 erikd@mega-nerd.com
< drwxr-xr-x 2 guest users 4096 Feb 25 15:52 eru@illuvatar.nu
< drwxr-xr-x 3 guest users 4096 Jan 11 19:13 esgoh@lycos.co.kr
< drwxr-xr-x 2 guest users 4096 Mar 14 12:27 esp@espsw.net
< drwxr-xr-x 4 guest users 4096 Feb 13 01:35 espress@cc.gatech.edu
< -rw-r--r-- 1 guest users 681245 Jan 27 16:43 ettercap-0.6.9.tar.gz
< drwxr-xr-x 5 guest users 4096 Mar 2 01:02 evilghost@stickit.nu
< drwxr-xr-x 4 guest users 4096 Mar 19 10:14 exceed@gmx.net
< drwxr-xr-x 2 guest users 4096 Jul 24 2002 fabiany@gmx.net
< drwxr-xr-x 2 guest users 4096 Jan 8 2001 fabio.barbon@realinformatica.it
< drwxr-xr-x 2 guest users 4096 Feb 15 15:52 fabio@informatec.com.br
< drwxr-xr-x 13 guest users 4096 Aug 15 2002 fabio@lmib.org
< drwxr-xr-x 2 guest users 4096 Dec 13 23:43 fan
< drwxr-xr-x 2 guest users 4096 Mar 17 2002 fanhow@yahoo.com
< drwxr-xr-x 2 guest users 4096 Jan 20 02:05 fanoush@seznam.cz
< drwxr-xr-x 3 guest users 4096 Oct 17 15:22 fatalbluescreen@attbi.com
< drwxr-xr-x 2 guest users 4096 Sep 16 2002 feagle@orgio.net
< drwxr-xr-x 2 guest users 4096 Sep 10 2002 febrian@supereva.it
< drwxr-xr-x 2 guest users 4096 Nov 6 21:08 feckelburger@gmx.net
< drwxr-xr-x 4 guest users 4096 Nov 11 05:08 fengd@colorado.edu
< drwxr-xr-x 2 guest users 4096 May 20 2002 feuerste@in.tum.de
< drwxr-xr-x 3 guest users 4096 Feb 17 09:58 ficco
< drwxr-xr-x 3 guest users 3481600 Feb 4 22:58 finance.yahoo.com
< drwxr-xr-x 2 guest users 4096 Dec 5 08:17 fiq@dreamthought.com
< drwxr-xr-x 2 guest users 4096 Sep 9 2001 fjugla@easter-eggs.com
< drwxr-xr-x 4 guest users 4096 Mar 7 03:48 flanker711@hotmail.com
< drwxr-xr-x 5 guest users 4096 Jan 21 06:51 flight@debian.org
< drwxr-xr-x 2 guest users 4096 Dec 15 2001 flo@0x17.org
< drwxr-xr-x 38 guest users 4096 Sep 27 09:32 florianbe@aec.at
< drwxr-xr-x 3 guest users 4096 Jan 22 12:08 foobar@doubledensity.de
< drwxr-xr-x 7 guest users 4096 Jul 21 2002 frank@ekern.no
< drwxr-xr-x 2 guest users 4096 Jul 11 2002 fraumeni@fas.harvard.edu
< drwxr-xr-x 16 guest users 4096 Nov 29 03:47 freek@freek.net
< drwxr-xr-x 3 guest users 4096 Feb 18 00:25 freesci
< drwxr-xr-x 2 guest users 4096 Aug 13 2001 frg@kki.net.pl
< drwxr-xr-x 3 guest users 4096 Oct 2 19:10 froo
< drwxr-xr-x 11 guest users 4096 Dec 19 18:56 ftemplin@iprg.nokia.com
< lrwxrwxrwx 1 guest users 3 Feb 17 12:43 g++ -> g++
< lrwxrwxrwx 1 guest users 8 Feb 17 12:43 g++-2.95 -> g++-2.95
< drwxr-xr-x 2 guest users 4096 Mar 20 09:47 gabe
< drwxr-xr-x 2 guest users 4096 Nov 18 07:14 gabriel@x3no.net
< drwxr-xr-x 14 guest users 4096 Feb 19 05:07 gael.eveno@free.fr
< drwxr-xr-x 3 guest users 4096 Dec 15 19:20 gangitano@lugroma3.org
< drwxr-xr-x 5 guest users 4096 May 25 2002 ganter@ganter.at
< drwxr-xr-x 2 guest users 4096 Sep 2 2002 gareth@woolridge.org.uk
< drwxr-xr-x 25 guest users 4096 Sep 9 2002 gberenfield@berenfield.com
< drwxr-xr-x 5 guest users 4096 Oct 14 18:21 gbickford@netacus.com
< drwxr-xr-x 2 guest users 4096 Jul 1 2002 gbrooks@tulmel.com
< drwxr-xr-x 9 guest kmem 4096 Apr 22 2001 gch@mit.edu
< drwxr-xr-x 2 guest users 4096 Jan 31 2002 gcolburn@zk3.dec.com
< drwxr-xr-x 2 guest users 4096 Jun 13 2002 gene79@freechal.com
< drwxr-xr-x 4 guest users 4096 Feb 9 16:45 gene@hacktek.com
< drwxr-xr-x 4 guest users 4096 Nov 29 18:09 genki@codeguru.li
< drwxr-xr-x 2 guest users 4096 Oct 11 02:18 gerhart.steiner@bigfoot.com
< drwxr-xr-x 3 guest users 4096 Dec 11 19:11 gf2e@andrew.cmu.edu
< drwxr-xr-x 7 guest users 4096 Nov 8 12:25 ggi
< drwxr-xr-x 33 guest users 4096 Sep 30 17:52 ghia@ccs.neu.edu
< drwxr-xr-x 2 guest users 4096 Sep 24 14:31 giglesia@ug.cs.usyd.edu.au
< drwxr-xr-x 7 guest users 4096 Nov 8 11:00 gii
< drwxr-xr-x 3 guest users 4096 Sep 24 14:31 giri@cs.sunysb.edu
< drwxr-xr-x 3 guest users 4096 Sep 24 14:31 giri@itrenders.com
< drwxr-xr-x 2 guest users 4096 Feb 24 06:19 girlman@ms62.url.com.tw
< drwxr-xr-x 5 guest users 4096 Oct 30 20:25 glama@c5.cl
< drwxr-xr-x 2 guest users 4096 Jan 14 08:28 glenn65535@netscape.net
< drwxr-xr-x 2 guest users 4096 Dec 3 07:56 glynn@info.ucl.ac.be
< drwxr-xr-x 5 guest users 4096 Oct 30 17:05 gmp
< drwxr-xr-x 7 guest users 4096 Nov 14 14:10 gn@drexel.edu
< drwxrwxrwx 4 guest users 4096 Oct 30 03:26 gobbo@solari.it
< drwxr-xr-x 4 guest users 4096 Nov 22 23:42 godfreyt@mit.edu
< drwxr-xr-x 2 guest users 4096 Nov 19 2001 goerg.pflug@epost.de
< drwxr-xr-x 3 guest users 4096 Sep 24 14:31 goodwink@percontor.com
< drwxr-xr-x 3 guest users 4096 Jan 4 12:28 gpsdrive
< drwxr-xr-x 4 guest users 4096 Nov 21 08:18 grass
< drwxr-xr-x 4 guest users 4096 Nov 16 2001 gray@cs.uni.edu
< drwxrwxrwx 6 guest users 4096 Oct 9 22:07 greg@cheers.bungi.com
< drwxr-xr-x 5 guest users 4096 Mar 2 14:03 greg@treke.net
< drwxr-xr-x 11 guest kmem 4096 Mar 23 2001 gremlin@gremlin.it
< drwxr-xr-x 2 guest users 4096 Sep 13 2001 gryn@plig.net
< drwxr-xr-x 2 guest users 4096 Nov 30 2001 gsun@broxon.com
< drwxr-xr-x 7 guest users 4096 Nov 20 04:53 gtkfbnocre
< drwxr-xr-x 2 guest users 4096 Jan 8 16:34 guest@yahoo.com
< drwxr-xr-x 2 guest users 4096 Sep 24 14:31 gui.uva.es
< drwxr-xr-x 5 guest users 4096 Mar 14 11:16 guiton@enseirb.fr
< drwxr-xr-x 2 guest users 4096 Jan 21 02:26 gurun@cs.ucsb.edu
< drwxr-xr-x 3 guest users 4096 Nov 14 02:16 gus@drexel.edu
< drwxr-xr-x 2 guest users 4096 Nov 18 14:40 gustave@drexel.edu
< drwxr-xr-x 2 guest users 4096 Sep 24 14:31 haa@iki.fi
< drwxr-xr-x 3 guest users 4096 Jan 24 00:53 haining
< drwxr-xr-x 2 guest users 4096 Nov 28 10:42 haldrik@optonline.net
< drwxr-xr-x 2 guest users 4096 Oct 15 18:41 han
< drwxr-xr-x 10 guest users 4096 Dec 10 09:29 handhelds@deanpemberton.com
< drwxr-xr-x 4 guest users 4096 Nov 18 14:38 hanna@potatothelizard.com
< drwxr-xr-x 9 guest users 4096 Jan 21 03:09 hardwire@bogomip.com
< drwxr-xr-x 13 guest users 4096 Feb 5 07:45 hari@vt100.at
< drwxr-xr-x 2 guest users 4096 Feb 18 23:37 harley@quasar.no-ip.org
< drwxr-xr-x 2 guest users 4096 Jan 9 23:16 havardi@yahoo.com
< drwxr-xr-x 3 guest users 4096 Oct 4 07:16 havardw@stud.ntnu.no
< -rw-r--r-- 1 guest users 21164 Mar 4 05:44 hci.h
< -rw-r--r-- 1 guest users 5607 Mar 4 05:44 hci_lib.h
< -rw-r--r-- 1 guest users 1495 Mar 4 05:44 hci_uart.h
< -rw-r--r-- 1 guest users 1315 Mar 4 05:44 hci_vhci.h
< drwxr-xr-x 2 guest users 4096 Oct 15 07:02 hector@debian.org
< drwxr-xr-x 2 guest users 4096 Feb 10 07:57 heeeha00@students.oamk.fi
< drwxr-xr-x 2 guest users 4096 Sep 24 14:30 heghan@kg21.net
< drwxr-xr-x 6 guest users 4096 Oct 18 06:31 heinbdv1@jhuapl.edu
< drwxr-xr-x 16 guest kmem 4096 Sep 24 14:30 hellhound@life.be
< -rw-r--r-- 1 guest users 67 Feb 21 12:31 hello.c
< drwxr-xr-x 4 guest users 4096 Mar 14 16:32 het2@linux.nu
< drwxr-xr-x 4 guest users 4096 Sep 24 14:30 het@chez.com
< drwxr-xr-x 2 guest users 4096 Aug 5 2001 heyoh@nologs.com
< drwxr-xr-x 4 guest users 4096 Jan 20 13:18 hidemano@hotmail.com
< drwxr-xr-x 5 guest users 4096 Mar 14 11:55 hien@enst.fr
< drwxrwxrwx 3 guest users 4096 Mar 7 06:40 hipp@sulzer.de
< drwxr-xr-x 2 guest users 4096 Feb 26 02:53 hkbt619@hongkong.com
< drwxr-xr-x 2 guest users 4096 Jan 24 01:06 hliu@uci.edu
< drwxr-xr-x 5 guest users 4096 Dec 9 11:07 hmader@tdt.de
< drwxr-xr-x 5 guest users 4096 Nov 19 10:11 hmw26@cam.ac.uk
< drwxr-xr-x 2 guest users 4096 Aug 9 2001 hoh@mococo.com
< drwxr-xr-x 3 guest users 4096 Dec 9 06:56 hop
< drwxr-xr-x 6 guest users 4096 Sep 20 06:11 hop@unibase.cz
< drwxr-xr-x 2 guest users 4096 Sep 20 2001 horf@nutz.com
< drwxr-xr-x 5 guest users 4096 Mar 3 04:02 hoschi@canitez.net
< drwxr-xr-x 2 guest users 4096 Jun 30 2002 hpadmana@aol.com
< drwxr-xr-x 2 guest users 4096 Oct 14 21:01 hubbe@hubbe.net
< drwxr-xr-x 3 guest users 4096 Oct 15 23:23 huid@colorado.edu
< drwxr-xr-x 5 guest users 4096 Sep 20 21:55 hwh
< drwxr-xr-x 2 guest users 4096 Feb 26 2002 ian.whitehouse@ukonline.co.uk
< drwxr-xr-x 2 guest users 4096 Oct 4 16:44 ian@polpo.org
< drwxr-xr-x 4 guest users 4096 Oct 24 08:12 iball@intrstar.net
< drwxr-xr-x 9 guest users 4096 Sep 24 14:30 idc@engr.ucsb.edu
< drwxr-xr-x 2 guest users 4096 Nov 19 2001 ilsfera@hotmail.com
< drwxr-xr-x 5 guest users 4096 Nov 19 06:55 include
< -rw-r--r-- 1 guest users 31701 Feb 4 12:09 index.html
< drwxr-xr-x 4 guest users 4096 Jan 22 12:29 indicos
< drwxr-xr-x 2 guest users 4096 Jul 1 2002 info@netrogenic.com
< drwxr-xr-x 3 guest users 4096 Feb 21 08:11 ipaq@7n7.de
< drwxr-xr-x 10 guest users 4096 Feb 21 08:11 ipaq@aidounix.com
< drwxr-xr-x 11 guest users 4096 Feb 21 08:11 ipaq@aljohnson.org
< drwxr-xr-x 10 guest users 4096 Feb 21 08:11 ipaq@internetbob.org
< drwxr-xr-x 4 guest users 4096 Feb 21 08:11 ipaq@neonDragon.net
< drwxr-xr-x 18 guest users 4096 Feb 21 08:11 ipaq@staaken.org
< drwxr-xr-x 2 guest users 4096 Feb 21 08:11 ipaq@walosi.net
< drwxr-xr-x 5 guest users 4096 Feb 21 08:11 ipaqdev@mufaza.dk
< drwxr-xr-x 2 guest users 4096 Jan 14 2001 is@colibri.de
< drwxr-xr-x 3 guest users 4096 Sep 24 14:30 ismael@stargate.com
< drwxr-xrwx 2 guest users 4096 Sep 24 14:30 iusty@ags.ro
< drwxr-xr-x 2 guest users 4096 Sep 24 14:29 j.s.pascoe@reading.ac.uk
< drwxr-xr-x 3 guest users 4096 Oct 24 18:33 j2deen_ca@yahoo.ca
< drwxr-xr-x 2 guest users 4096 Jul 19 2001 jackal@astercity.net
< drwxr-xr-x 17 guest users 4096 Mar 9 01:35 jacob@gnu.org
< drwxr-xr-x 2 guest users 4096 Nov 14 19:43 jade384@aol.com
< drwxr-xr-x 2 guest users 4096 Mar 3 09:05 jae
< drwxr-xr-x 2 guest users 4096 Mar 17 06:01 jaeran00@oamk.fi
< drwxr-xr-x 3 guest users 4096 Oct 22 08:46 jamesp@hisser.org
< drwxr-xr-x 2 guest users 4096 Feb 28 06:55 jametller@ccd.uab.es
< drwxr-xr-x 2 guest users 4096 Mar 5 17:15 jan@stoefer.com
< drwxr-xr-x 2 guest users 4096 Dec 2 12:03 jarmo.hiipakka@hut.fi
< drwxr-xr-x 4 guest users 4096 Dec 20 2001 jason@haslup.com
< drwxr-xr-x 2 guest users 4096 Dec 9 15:35 jatumass@yahoo.com
< drwxr-xr-x 2 guest users 4096 Sep 24 14:29 jbarba@inf-cr.uclm.es
< drwxr-xr-x 13 guest users 4096 Oct 18 01:24 jbardin@hsc.usf.edu
< drwxr-xr-x 3 guest users 4096 Sep 24 14:29 jblack@linuxguru.net
< drwxr-xr-x 2 guest users 4096 Jan 24 14:44 jbt
< drwxr-xr-x 2 guest kmem 4096 Sep 24 14:29 jcalvar@iies.es
< drwxr-xr-x 2 guest users 4096 Mar 6 09:39 jchamoun@inf.enst.fr
< drwxr-xr-x 2 guest users 4096 Oct 3 19:54 jcpark@ece.gatech.edu
< drwxr-xr-x 3 guest users 4096 Oct 9 20:32 jcw@equi4.com
< drwxr-xr-x 2 guest users 4096 Jul 26 2001 jd_hodges_ii@hotmail.com
< drwxr-xr-x 2 guest users 4096 Mar 13 2002 jeff_mcdonald@hotmail.com
< drwxr-xr-x 5 guest users 4096 Mar 1 03:21 jens@hb9zz.ethz.ch
< drwxr-xr-x 6 guest users 4096 Sep 24 14:29 jerome_baumgarten@yahoo.fr
< drwxr-xr-x 5 guest users 4096 Nov 21 12:41 jestin@cena.fr
< drwxr-xr-x 3 guest users 4096 Nov 20 05:27 jestin@cena.fr:ivystroke
< drwxr-xr-x 18 guest users 4096 Dec 30 13:23 jfran@<removed>-engine.com
< drwxr-xr-x 10 guest users 4096 Mar 10 15:29 jfraumeni@orangeimagineering.com
< drwxr-xr-x 2 guest users 4096 Feb 16 21:59 jg@false.net
< drwxr-xr-x 3 guest users 4096 Dec 19 11:44 jgorkos@slb.com
< drwxr-xr-x 2 guest users 4096 Feb 11 2001 jhe2@student.gsu.edu
< drwxr-xr-x 2 guest users 4096 Aug 11 2001 jhhudso@volumehost.com
< drwxr-xr-x 2 guest users 4096 Dec 20 15:07 jhogie@usemail.com
< drwxr-xr-x 4 guest users 4096 Mar 12 03:56 jht@iki.fi
< drwxr-xr-x 2 guest users 4096 Jul 4 2001 jim@spsu.edu
< drwxr-xr-x 2 guest users 4096 Aug 19 2001 jjw19@cornell.edu
< drwxr-xr-x 2 guest users 4096 Nov 12 17:06 jkorb@mitre.org
< drwxr-xr-x 6 guest users 4096 Aug 1 2002 jkyro@cs.helsinki.fi
< drwxr-xr-x 2 guest users 4096 Aug 24 2002 jl@kth.se
< drwxr-xr-x 4 guest users 4096 Sep 24 14:29 jlavi@iki.fi
< drwxrwxrwx 2 guest kmem 4096 Jun 15 2002 jls@sody.com
< drwxr-xr-x 4 guest users 4096 Nov 26 12:52 jmerinen@iki.fi
< drwxr-xr-x 2 guest users 4096 Dec 9 13:43 jmgiza@student.umass.edu
< drwxr-xr-x 3 guest users 4096 Sep 24 01:37 jn_k@gmx.de
< drwxr-xr-x 2 guest users 4096 Mar 12 21:00 jni
< drwxr-xr-x 2 guest users 4096 Dec 6 2001 joe@etm.ercsson.se
< drwxr-xr-x 2 guest users 4096 Sep 8 2001 joerg@0n3.de
< drwxr-xr-x 2 guest users 4096 Jul 6 2002 joerg@0n3.org
< drwxr-x--- 2 guest users 4096 Sep 24 04:09 johan.damen@philips.com
< drwxr-xr-x 2 guest users 4096 Oct 9 22:07 johan@webspace.se
< drwxr-xr-x 3 guest users 4096 Feb 16 02:26 john.cabrer@rocketmail.com
< drwxr-xr-x 2 guest users 4096 Jan 8 18:51 john.milton@usa.net
< drwxr-xr-x 3 guest users 4096 Sep 24 14:29 john@coastalgeology.org
< drwxr-xr-x 2 guest users 4096 Sep 28 2001 johnl@blurbco.com
< drwxr-xr-x 12 guest users 8192 Feb 13 23:04 johnson55
< drwxr-xr-x 3 guest users 4096 Mar 4 12:12 joknecht@hotmail.com
< -rwxr-xr-x 1 guest users 4488 Feb 21 12:36 joknecht@hotmail.com:prova
< drwxr-xr-x 2 guest users 4096 Sep 24 14:29 jon@daisymaths.com.au
< drwxr-xr-x 2 guest users 4096 Feb 25 09:52 jonath-k@is.aist-nara.ac.jp
< drwxr-xr-x 2 guest users 4096 Aug 22 2001 joon78@qlife.co.kr
< drwxr-xr-x 7 guest users 4096 Dec 5 09:52 jordan@d0pe.com
< drwxr-xr-x 2 guest users 4096 Nov 14 14:57 jordan@localhost
< drwxr-xr-x 2 guest users 4096 Feb 25 2001 jordang@pcc.net
< drwxr-xr-x 2 guest users 4096 Feb 27 18:28 jordi
< drwxr-xr-x 2 guest users 4096 Mar 1 09:48 jordiotero@hotmail.com
Please try the leatest version of WinSCP. Also turn on logging without log window shown.
Pentad
. Listing file "g++".
> ls -lad "g++" ; echo "WinSCP: this is end-of-file:$?"
It never comes back.
Any thoughts???
You have cyclic symlink there, WinSCP cannot handle these.
