Topic "Session password issue"
dan
If I use putty or psftp I can sucessfully login to the server, if I use winscp it keeps asking for session password. I have already entered the user amd pw in the session dialog, what am I missing?
Dan
d_original
i have same problems, would be glad if some had a solution to this issues?
PS:before i got this problem i entered the login details and save the session now when i try to login it keeps asking for the session password which i entered same as the login password.
First, check the server's log to see why it denies you to login.
Rocknolds
How and where will I get to see the logs that you are talking? I can connect using SSH (Putty) to my Fedora4 Linux server.
Thanks a lot.
rctablada@...
I hope this will help. Thanks
. 2005-10-18 21:31:11.549 --------------------------------------------------------------------------
. 2005-10-18 21:31:11.549 WinSCP Version 3.7.6 (Build 306) (OS 5.1.2600 Service Pack 2)
. 2005-10-18 21:31:11.549 Login time: Tuesday, October 18, 2005 9:31:11 PM
. 2005-10-18 21:31:11.549 Session name: session
. 2005-10-18 21:31:11.549 Host name: 172.16.68.10 (Port: 22)
. 2005-10-18 21:31:11.549 User name: rtablada (Password: Yes, Key file: No)
. 2005-10-18 21:31:11.549 Transfer Protocol: SFTP (SCP)
. 2005-10-18 21:31:11.549 SSH protocol version: 2; Compression: No
. 2005-10-18 21:31:11.549 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2005-10-18 21:31:11.549 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2005-10-18 21:31:11.549 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2005-10-18 21:31:11.549 SSH Bugs: -,-,-,-,-,-,-,-
. 2005-10-18 21:31:11.549 SFTP Bugs: -,-,-
. 2005-10-18 21:31:11.549 Proxy: none
. 2005-10-18 21:31:11.549 Return code variable: Autodetect; Lookup user groups: Yes
. 2005-10-18 21:31:11.549 Shell: default, EOL: 0
. 2005-10-18 21:31:11.549 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2005-10-18 21:31:11.549 Cache directory changes: Yes, Permanent: Yes
. 2005-10-18 21:31:11.549 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2005-10-18 21:31:11.549 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2005-10-18 21:31:11.549 Looking up host "172.16.68.10"
. 2005-10-18 21:31:11.549 Connecting to 172.16.68.10 port 22
. 2005-10-18 21:31:11.564 Server version: SSH-2.0-OpenSSH_4.0
. 2005-10-18 21:31:11.564 We claim version: SSH-2.0-WinSCP_release_3.7.6
. 2005-10-18 21:31:11.564 Using SSH protocol version 2
. 2005-10-18 21:31:11.564 Doing Diffie-Hellman group exchange
. 2005-10-18 21:31:11.611 Doing Diffie-Hellman key exchange
. 2005-10-18 21:31:12.002 Host key fingerprint is:
. 2005-10-18 21:31:12.002 ssh-rsa 1024 53:a7:95:6e:d3:77:46:9e:5b:6b:17:a8:3d:a2:2a:f4
. 2005-10-18 21:31:12.002 Initialised AES-256 client->server encryption
. 2005-10-18 21:31:12.002 Initialised HMAC-SHA1 client->server MAC algorithm
. 2005-10-18 21:31:12.002 Initialised AES-256 server->client encryption
. 2005-10-18 21:31:12.002 Initialised HMAC-SHA1 server->client MAC algorithm
! 2005-10-18 21:31:12.033 Using username "rtablada".
. 2005-10-18 21:31:12.033 Session password prompt (rtablada@172.16.68.10's password: )
. 2005-10-18 21:31:12.033 Using stored password.
. 2005-10-18 21:31:12.033 Sent password
! 2005-10-18 21:31:14.690 Access denied
. 2005-10-18 21:31:14.690 Access denied
. 2005-10-18 21:31:14.690 Session password prompt (rtablada@172.16.68.10's password: )
. 2005-10-18 21:31:14.690 Asking user for password.
. 2005-10-18 21:31:16.002 Unable to authenticate
. 2005-10-18 21:31:16.002 Attempt to close connection due to fatal exception:
* 2005-10-18 21:31:16.002 Unable to authenticate
. 2005-10-18 21:31:16.002 Closing connection.
* 2005-10-18 21:31:16.002 (ESshFatal) Authentication failed.
* 2005-10-18 21:31:16.002 Authentication log (see session log for details):
* 2005-10-18 21:31:16.002 Using username "rtablada".
* 2005-10-18 21:31:16.002 Access denied
This FAQ may help you.
richdog
Has your password changed recently? It sounds as if you have a stored password somewhere in WinSCP that is no longer valid, or your password on your SSH server is no longer valid.
carolathompson
I have a somewhat different version of this problem. I just changed several Unix server passwords yesterday. I can now telnet into these servers, but both WinSCP and Putty give me authentication errors on these same servers. Do they have trouble with special characters in passwords? I was using "!" in my passwords and I just changed it.
Carol A Thompson
carolt@wellsfargo.com
Check the SSH server log file.
Noname
In my case, the problem was fixed by changing the preferred protocol number from 1 to 2 in WinSCP. Perhaps v.1 is no longer supported by default in SUSE Linux 9.3.
I had a similar problem when I upgraded SUSE. I could login with Puty but not SCP. Changing SSH protocol from 1 to 2 fixed my problem also. Thanks.
Pythagoras1
still no luck with all the hints Sad
i even tried to set the password on the server again and changing protocol and encryption did not make a difference. winscp keeps asking me for a session password while putty works.
here is the client log:
. WinSCP Version 2.0.0 (Build 110)
. Login time: Freitag, 09. Februar 2007 20:13:43
. Session name: mayly@192.168.0.73
. Host name: 192.168.0.73 (Port: 22)
. User name: mayly (Password: Yes, Key file: No)
. Agent forwarding: No; TIS/CryptoCard authentication: No
. Imitate SSH2 MAC bug: No; Cipher: 3des
. Ping interval: 0 min (0 = off)
. Shell: default, EOL: 0
. Local directory: default, Remote directory: home, Update: No
. Clear aliases: Yes, Unset nat.vars: Yes
. Server version: SSH-2.0-OpenSSH_4.5
. We claim version: SSH-2.0-PuTTY
. Host key fingerprint is:
. 1024 a1:38:ed:39:3d:2d:f5:3d:4d:f2:dc:44:b2:c9:71:ad
. Initialised triple-DES client->server encryption
. Initialised triple-DES server->client encryption
! Access denied
. Authentication refused
! Access denied
! Access denied
. No more passwords to try
I set the ssh daemon on the server on its highest debug level "DEBUG3" and this is what i got when connecting. this is the server log:
debug3: fd 4 is not O_NONBLOCK
debug1: rexec start in 4 out 4 newsock 4 pipe 6 sock 7
debug1: Forked child 8636.
debug3: send_rexec_state: entering fd = 7 config len 215
debug3: ssh_msg_send: type 0
debug3: send_rexec_state: done
debug1: inetd sockets after dupping: 3, 3
Connection from 192.168.0.1 port 4272
debug1: Client protocol version 2.0; client software version PuTTY
debug1: no match: PuTTY
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_4.5
debug2: fd 3 setting O_NONBLOCK
debug2: Network child is on pid 8640
debug3: preauth child monitor started
debug3: mm_request_receive entering
debug3: monitor_read: checking request 4
debug3: mm_answer_sign
debug3: mm_answer_sign: signature 0x56b210(55)
debug3: mm_request_send entering: type 5
debug2: monitor_read: 4 used once, disabling now
debug3: monitor_read: checking request 6
debug3: mm_answer_pwnamallow
debug3: Trying to reverse map address 192.168.0.1.
debug2: parse_server_config: config reprocess config len 215
debug3: mm_answer_pwnamallow: sending MONITOR_ANS_PWNAM: 1
debug3: mm_request_send entering: type 7
debug2: monitor_read: 6 used once, disabling now
debug3: monitor_read: checking request 45
debug1: PAM: initializing for "mayly"
debug1: PAM: setting PAM_RHOST to "192.168.0.1"
debug1: PAM: setting PAM_TTY to "ssh"
debug2: monitor_read: 45 used once, disabling now
debug3: monitor_read: checking request 3
debug3: mm_answer_authserv: service=ssh-connection, style=
debug2: monitor_read: 3 used once, disabling now
this is where winscp permanently asks for a password but no password attempts are shown in the log file. when i press cancel the log just gives me one single line:
debug1: do_cleanup
that's all, no error, nothing. i already tried an other username. also checked the config:
Subsystem sftp /usr/lib64/misc/sftp-server
this looks like winscp doesn't even send any password and thinks it was wrong or something like that.
Please download the recent version of WinSCP. (For short time, very ancient version was linked from download page by mistake).
isma44
My SFTP server is running on the Windows.
I was suffering the same problem...
but I solved this problem,
with the restarting of SFTP service.
FYI, my SFTP service is freeFTPd.
