Topic "Connect on 2nd Server over the first one ?"
aNj
Hi!
Is there a posibility to connect to a server which is not avaiable directly through ssh.
Normaly i use putty to connect to first one, and then I connect with the ssh command to the second server, but I want the features of SFTP?!?!
How does it work?!
Thx!
Best regards!
aNj
With SFTP you cannot do this. With SCP, it is theoretically possible. Try to search the forum, you may find hints from other users.
