Topic ""More" not working on Windows XP Professional"
Vladimir Anisimov
The "More" button in WinSCP 2.2 works on Windows NT, but does not work on Windows XP Professional. It just makes the window bigger, but the additional space is blank.
In other words, this F.A.Q. is not true:
3. Where can I change file transfer mode (binary, ascii) or enable auto-select transfer mode option?
Invoke copy confirmation dialog (start copying any file) and press "More" button. Additional copy options show up (including transfer mode options).
Additional copy options do not show up. This bug was introduced recently. Some earlier versions were correct.
Thank you,
Wlodek
I works for me (on WinXP). Do you have some idea, what might cause this?
OK, I does not work Smile
It works only if dialog is "expanded" when opened. So if you open it not expanded, than expand it, copy file (so settings is saved) and that open it once again, it should be displayed correctly.
I'll fix it next release.
ninja_k
hi!
has anyone reported that winscp loves to hang on large transfers under my winxp professional ?
I can't seem to duplicate it on another machine; however, the particular machine in question is a fresh/vanilla XP install.
Very Weird.
Dunno what you can do about it,but if you have any suggestions on where I can start to look to figure out what's going on, that'd be great. (perhaps a debug build that does some sort of logging?)
