Masks
IAmAI
Masks
I am completely failing to comprehend how masks are supposed to work with transfer presets. Example:
usr/public_html/*
Why, oh why, does the above mask not match any file, within any subdirectory of any depth? It seems logical to me that it should do. Are slashes excluded from applying to *? Please can someone tell me what string I must use in order for the preset to apply to any file a copy to the public_html directory and within any of its subdirectories of any depth? I have tried all sorts and nothing does what I would logically expect nor what I'd like it do. I have read the Masks page, however that has not helped.
IAmAI
Actually, I didn't specify the exact directory I am trying to use - I didn't feel it necessary to reveal the directory structure of the server I'm connecting to (and I also described it as an 'example). However, I can tell you that I used the Current button, which does procede the current directory with a backwards slash.
Are you sure with the "backward" slash? For remote directory?
Also, what are you tring to do? "Current" button is on transfer setting autoselection mask. So I suppose you play with it. The mask there is not supposed to select file, but directories.
IAmAI
No, sorry; I mean forward slash. I am trying to select directories: I want to select all the subdirectories of any depth within 'public_html' and the 'public_html' directory itself.
IAmAI
That works for the 'public_html' directory and any immediate subdirectories, but will not match any subdirectories deeper than one level, for example:
/usr/public_html/subdir1/subdir2
The preset it not matched to 'subdir2' when it is browsed to, not will any of its subdirectories of any depth. I wish it to apply to any depth.
Sorry, you are right. Following mask will do:
/usr/public_html;/usr/public_html/*;/usr/public_html/*/*
Shorter, but less precious form is:
/usr/public_html;/usr/public_html*/*
